Vodafone McLaren MP4-27 Mercedes
Owen.C93
Owen.C93
191
Re: Vodafone McLaren MP4-27 Mercedes
morefirejules08 wrote:Would it be possible for McLaren to retain the upper profile of there nose while changing the underside to what we see on the stepped nose cars?
Not without crushing their drivers feet. Plus I think there's a reg for bulkhead dimensions.
astracrazy
astracrazy
31
why is the focus on the front of the car, when in red bulls case, there major update was the rear (exhausts mainly) which has gave them such a forward step. Shouldn't mclaren perhaps be looking at there exhaust/rear end set-up first?
THink of it like a river. If have cows passing faeces at the river head, then youre gonna have cow dung downstream.
N12ck
n smikle wrote:THink of it like a river. If have cows passing faeces at the river head, then youre gonna have cow dung downstream.
excellent analogy, sums up the airflow around a f1 car perfectly, cow dung in a river =D> although on a serious note, get the air going to the rear, then deal with the rear :D
Budding F1 Engineer
astracrazy
astracrazy
31
I know, i'm just wondering if the exhaust solution is that dependent on the front?
Huntresa
Huntresa
astracrazy wrote:why is the focus on the front of the car, when in red bulls case, there major update was the rear (exhausts mainly) which has gave them such a forward step. Shouldn't mclaren perhaps be looking at there exhaust/rear end set-up first?
Maybe because they alrdy exhausted all the possibilities of development at the front ? Something mclaren hasnt not running a stepped nose and all.
N12ck
yes, because if the air doesnt get to the correct place on the rear you cannot divert the air for your exhaust solution, to direct the exhaust gases to the diffuser
Budding F1 Engineer
Owen.C93
Owen.C93
191
Lets say for every update they bring to the rear they gain 10points of downforce right now, but if they raise the nose and have more flow to the floor then now each of those updates brings 12.5points of downforce, plus any benefits they gain from the initial raising of the nose.
Chuckjr
How many pounds/kilos is a "point" of downforce?
Shame they may have to go to stepped nose. The Macca is...well...was...one great looking car. I thought Lewis said at the beginning of the year that "beautiful is fast"...I guess we all know that's just simply not true.
Watching F1 since 1986.
raymondu999
Each team quantify downforce "points" differently - it's an arbitrary scale each team decides for their own internal use. To memory, Macca says every point of downforce is half a tenth (0.05 seconds).
In said context, 10/12.5 points of downforce seems a bit excessive. Was that just a random, arbitrary number to illustrate your point, perhaps?
EDIT: I'm talking rubbish. A "point" is talking in terms of cl, where 1 added point is 0.01 more in terms of cl.
Try looking here: viewtopic.php?f=6&t=8250
Q: Jenson Button has suggested you were ‘30 points’ behind Red Bull in terms of downforce and that it would take six or seven races to make up that deficit. Do you agree with that analysis and can you explain what ‘30 points’ means?
Paddy Lowe: A point is Formula One code for a hundredth of a fraction of ‘cl’, where ‘cl’ is the downforce coefficient. Physically a Formula One car has a downforce coefficient of let’s say 3 to 3.5. So 30 points would be 30 hundredths which would equate to 0.3. So 30 points might be getting on for 10 percent of the downforce on an F1 car and that could be worth about a second a lap.
失败者找理由,成功者找方法
Owen.C93
Owen.C93
191
Yeah it was an arbitrary number to demonstrate my point. The idea of a 25% increase was also just to show my point more clearly.
Owen.C93
Owen.C93
191
n smikle wrote:High nose!! It's coming!! :shock: Watch the car on Friday!
Does it look much higher?
No and you can pretty clearly see the slight downwards bend on the top surface.
Owen.C93
Owen.C93
191
Old version for comparison:
Nothing obviously new on that front. Hopefully when it's built we'll see some of the updates they mentioned.
McMrocks
McMrocks
32
were the sidepods always so small?
