Monaco will be a lottery.
Beware of T-Rex
napoleon1981
napoleon1981
DDopey wrote:
18 May 2025, 17:58
Provocative opinion: I think the overtake of today proofs he could have made the corner in Jeddah if he was not pushed wide. He is that brilliant in braking.
Yes that is what I was saying. Put gravel traps down, Oscar knew he couldn't open up the steering this time.
Cs98
Cs98
napoleon1981 wrote:
19 May 2025, 00:00
DDopey wrote:
18 May 2025, 17:58
Oscar could and should have opened up the steering. Rest assured if the roles were reversed Piastri would have been going through the gravel, we already saw that in 2021 between Verstappen and Hamilton in that corner. Piastri let Max get the better of him, and he lost the race because of it.
napoleon1981
napoleon1981
He would have wrecked had he opened up the steering. It was a wise decision, and running competitors off track has nothing to do with racing. Old school track and old school overtaking I like it.
Piastri would have lost the race anyway, Max would have taken him with the car today. Dirty air and all.
chrisc90
Cs98 wrote:
19 May 2025, 00:03
napoleon1981 wrote:
19 May 2025, 00:00
DDopey wrote:
18 May 2025, 17:58
If Oscar did that he would have got a penalty.
Of course, the problem arose by Oscar not moving over to the ‘racing line’ allowing Max to take the corner as normal.
Given Max was behind George on the run up, Oscar had all the room to move over to the right and block Max off.
Rookie error. Oscar probably thought the inside would make it his corner under the ‘new’ driving rules, but Max showed him who was boss with that one.
19 May 2025, 00:00
This car can seemingly ride kerbs now, and they seem to have made a step that allows them to find better setups according to Verstappen, so 'max factor' could deliver something special. i would imagine it'll be between Max and Piastri
Cs98
Cs98
chrisc90 wrote:
19 May 2025, 00:07
Cs98 wrote:
19 May 2025, 00:03
napoleon1981 wrote:
19 May 2025, 00:00
You obviously have to combine it with the right brake pressure to make sure you are marginally ahead from the apex whilst staying on track, which was fully possible. Instead he got done like few have been done before. We don't have dunks in F1 but that kind of felt like a slam dunk. Someone needs to make a poster.
AGOW
AGOW
19 May 2025, 00:00
Not really a lottery if Verstappen can deliver in quali like he has been over the past few weekends. The slower corners might be troublesome for the RedBulls however.
A victory shouldn't be too difficult if he does get pole.
19 May 2025, 00:30
19 May 2025, 00:00
I think they have chances, but red flags in qualy, VSC, and SCs can make for a bad result even if you are fast. You have to be very lucky with the 2 mandatory stops.
Beware of T-Rex
19 May 2025, 00:40
19 May 2025, 00:30
19 May 2025, 00:00
That's probably good for us. More randomness to hurt the McLarens who are outright favourites
Paa
I kind of wish Barcelona will be fairly hot.
Then we would get a decent picture on how the season will go with all teams with their main upgrade package on and with TD implemented.
ispano6
164
Cs98 wrote:
18 May 2025, 20:56
CjC wrote:
18 May 2025, 20:48
I disagree, I wouldn’t have said Mclaren have lost anything.
Look at the pace today that Mclaren had over everyone else but Max. It’s Max that have improved rather than Mclaren ‘loosing’ something.
Fact of the matter is Mclaren didn’t have a soul destroying advantage over everyone in Japan and Saudi, now that the Red Bull has successfully upgraded by a minimum of 2 tenths Max can match and beat the McLarens now.
Thermal deg is McLarens real advantage and that wasn’t a factor today
It was for many cars, the question is why it wasn't for Verstappen. That will be the thing to keep your eyes on going forward, if RB truly has "found" something, or if it's just on certain tracks the deg is good, like Japan and Saudi.
Previously it was more a matter of the conditions. Max said thermal deg in Suzuka was kept in check because sector 1 was re-paved and had more grip and less abrasive plus the lower track temperatures due to cloud cover and ambient temps. It's been speculated that Saudi was also kinder on the tyres because there was no direct sunlight. The overheating of tyres was contributed by both core and carcass temperatures. The issue of core temperature seems to have been addressed with the upgraded brakes. The carcass temp issue has been reduced thanks to less sliding.
venkyhere
45
ispano6 wrote:
19 May 2025, 04:34
Guys help me get clarified with basics of tyre deg :
1. thermal deg = core temp overshoots due to rubber flexing violently due to lateral/longitudinal loading. Is this correct ?
2. graining / blistering = due to surface/carcass temp being not-in-step with core temp, higher carcass temp in case of too much sliding, lower carcass temp in case of too aggressive outlaps on fresh tyres (when the tyres are NOT brought in gently). Which case is blistering which case is graining ? I get confused.
3. lower tyre pressures - what are they meant to aid ? are they going to help reduce sliding (due to more flex) but increase core temp / thermal deg or vice versa ?
Aesop
Aesop
19 May 2025, 00:30
19 May 2025, 00:00
Let's see how the updates work for the slow corners, besides riding the kerbs that was a main weakness.
avantman
avantman
I read so much nonsense from so-called experts and analysts now declaring peremptorily that Red bull was the faster car than the Mclaren in Imola. Those so-called analysts forgot that Max V owned Bottas in Imola already in 2020 having incomparably and undoubtedly slower car. Bottas who was not much slower driver in 2020 than Piastri is now.
On both first two stints it was Mclaren driver who set the faster lap(Norris in the 1st stint, Piastri in the 2nd), despite driving extremely compromised stints, battling with other cars for position, driving in dirty air damaging the tires. So, Max opened up the gap to Piastri who had old tires after the safety car. Then Norris couldn't close that gap after overtaking Piastri, whilst it was clear he never even tried knowing he could do nothing having just few laps left in the race and those analysts say Red bull was the faster car. Nothing, literally nothing suggests red bull was the faster car on Sunday.
