Williams FW36 Mercedes
mrk189
mrk189
Re: Williams FW36 Mercedes
el-Magico wrote:
This car really look great!!
Looks great yes, very fast, maybe not :shock:
You don't need a licence to drive a sandwich
Mr Brooksy
Anyone got access to lap time data especially for long runs yesterday? I'm a bit disappointed in FP2 as they seemed off the pace more than expected. However I know it's FP2 not qualifying or race.
WilliamsF1 fan since 1989
FrukostScones
they need NASA as sponsor.
"I ain't with the FIFA, I'm in Tokyo." LH
Mr Brooksy wrote:Anyone got access to lap time data especially for long runs yesterday? I'm a bit disappointed in FP2 as they seemed off the pace more than expected. However I know it's FP2 not qualifying or race.
http://en.mclarenf-1.com/index.php?page ... 314&graf=3
Select Bottas as one of the drivers and compare to who you want.
Mercedes is faster, Williams and Redbull follow imo.
FP2 fastest lap was just ok, but i think Williams held back given that Bottas did a 32.4 on 27 lap old medium tires in FP1, and on 7 lap run no less without backing off on the previous one.
Mr Brooksy
Someone on Williams Facebook page asked why Bottas was only running 12000rpm during fp2. Are teams restricting rpm to make the 100kg fuel restriction for the race?
240
jagunx51 wrote:interesting ..... where is "the blue" comes from ?
http://imageshack.com/a/img534/860/zt1w.jpg
That device around the exhaust pipe, what is it?
Is it cooling something?
Owen.C93
Owen.C93
192
Mr Brooksy wrote:Someone on Williams Facebook page asked why Bottas was only running 12000rpm during fp2. Are teams restricting rpm to make the 100kg fuel restriction for the race?
Fuel flow limit makes anything over 12k pointless, except maybe in top gear.
jagunx51
185
dren wrote:
Holm86 wrote:Im 100% sure thats where the wastegate connects to the exhaust.
Yes, evidence they are using a wastegate.
now we need a clear pic from side view.... :?:
Steven
Owner
No we don't. It's obvious. And just to be clear, Renault and Mercedes have repeatedly stated that they would have a wastegate for safety. The ERS-H would make a wastegate unneeded, but in case of a failure of that system, a wastegate is absolutely necessary to prevent the turbo from failing is well, which would then also lead to an entire power unit failure.
On the grid, Massa said to Barrichello that the car is quite low drag that's why it sucked in the rain.
A good shot of the rear (screw you Koba :evil: )
jagunx51
185
for comparison .... ct05's wastegate
-Felix-
-Felix-
On the onboard shots from the nose pointing at the front suspensions, i noticed that the pushrod on the williams was expanding on the upright side in rebound (so the inner wheel in a curve). Anyone else noticed that? Haven't seen that before, anyone knows something about it and it's purpose?
Leon
Leon
-Felix- wrote:On the onboard shots from the nose pointing at the front suspensions, i noticed that the pushrod on the williams was expanding on the upright side in rebound (so the inner wheel in a curve). Anyone else noticed that? Haven't seen that before, anyone knows something about it and it's purpose?
around 2 min?
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
-Felix-
-Felix-
I also searched for videos and saw that one. It's hardly visible, there were shots on tv where it was much obvious. But you can spot it if you know where to look. On the pushrod below the composite there is a silver area and below that a kind of gold part (insert or some mechanical part). That's the one which was extending.
Edit:
From 10:20 till 10:25
https://www.youtube.com/watch?v=vQBtQBNX-7w
Mark4211
92
Did Pat Symonds brought the FRIC from last year's Marussia to this years Williams?
It seems like it. Upon corner turn in, the inside suspension vibrates vigorously similar to last year's Marussia.
