Williams FW36 Mercedes
michl420
michl420
Re: Williams FW36 Mercedes
I noticed that "vibrates" also, but for me the whole front suspension works different (more), to mclaren at least.
kaido
kaido
Sevach wrote:On the grid, Massa said to Barrichello that the car is quite low drag that's why it sucked in the rain.
not surprising Bottas had very good top speed (within top 3 for each sector)
Sector 1: 77 V. BOTTAS 275.7
Sector 2: 77 V. BOTTAS 303.2
Sector 3: 77 V. BOTTAS 303.3
That's a combo of low drag, Merc power and spending most of the race in someone's slipstream :mrgreen:
Huntresa
Huntresa
But then again at times he was far behind the others and just reeled them in, i was especially amazed over the traction coming out of the first corner compared to the Ferrari he was chasing, he just ate up meter by meter before the DRS even started on the 2nd straight.
Matt Somers
Matt Somers
179
A shot of the Williams push rod movement from the BBC footage
http://s3.photobucket.com/user/Somersra ... 5.mp4.html
OO7
OO7
171
Matt Somers wrote:A shot of the Williams push rod movement from the BBC footage
There was some footage during practice or qualification of one of the Williams' negotiating Turn 2, with the left front bouncing up and down over the track surface (not the curbing).
tomazy
tomazy
231
Interesting, is seems like it gives the suspention a bit of extra trevel distance. Probably that the inside wheel in a corner 'falls' to the ground quicker when running agresivly over the curb?
el-Magico
el-Magico
-10
Location: The number above shows the current temperature
Is that legal?
Quote of the year: "almost as sickening as the Velcro fluff under Lewis' cap..."
Lycoming
Lycoming
106
That's weird... it looks like it's opening up under compression.
Owen.C93
Owen.C93
192
Having a 2 stage spring effectively allows to to run softer on the inside wheel at high roll angles. As far as I'm aware it's legal but I don't understand why it's done at the hub end of the pushrod.
LookBackTime
LookBackTime
472
Owen.C93 wrote:Having a 2 stage spring effectively allows to to run softer on the inside wheel at high roll angles. As far as I'm aware it's legal but I don't understand why it's done at the hub end of the pushrod.
Lower CoG !?
To disconnect the hub from the damper, they're not just trying to reduce the springrate - you'd just do that with pushrod geometery - they're trying to deliberate excite the hub when the loads are low, probably for keeping more temperature in the front unloaded tyre?
holeindalip
holeindalip
It was bouncing up and down because he had just locked the brakes and had a major flat spot on the tire, watch the footage again.
Interesting. The FW-36 seems to be a very fast car though. The high top speeds and the low consumption (Bottas's race) would mean the Williams is mainly relying on its floor and diffuser for downforce (its nice floating sidepods could explain this) and is running with 'flatter' wings. That would expalin it's relatively poor pace under the rain; maybe its low floor works worse in those condition and hence the wings are low AoA, it cant rely on their direct and cheap DF.
Owen.C93
Owen.C93
192
To disconnect the hub from the damper, ... they're trying to deliberate excite the hub when the loads are low, probably for keeping more temperature in the front unloaded tyre?
That's it.
