Ferrari F14T
i70q7m7ghw
i70q7m7ghw
49
Re: Ferrari F14T
emmepi27 wrote:I've tried to enhance flo-vis
Nose cone:
https://pbs.twimg.com/media/BfFWq21CQAAA-mR.jpg:large
Diffuser & b-side
https://pbs.twimg.com/media/BfFVLMQCQAAG97Q.jpg:large
It doesn't need enhancing, you're just trying to find a reason to stamp your blog all over the picture.
PABLOEING
PABLOEING
Re: Ferrari F14T
I see the front wing very "Basic" in comparation with the other cars.......¿near updates in this area?
Mr.G
34
Re: Ferrari F14T
Lorenzo_Bandini wrote:Thanks to ScottMB from Autosport forum.
http://www.youtube.com/watch?v=Vf5hN6Re ... tube_gdata
Looks good, even the flow vis looks good to me, no turbulences. Flow going like I was expecting. And the sound, the sound is brutal!!!
EDIT: Listen to 0:05 it sounds like last year blowing...
diemaster
diemaster
Re: Ferrari F14T
Kimi : V6 power not so different from V8 powered cars
http://motorsport.nextgen-auto.com/V6-p ... 71916.html
Owen.C93
Owen.C93
191
Re: Ferrari F14T
That's the car going over the rumble strips.
Rhino
Rhino
Re: Ferrari F14T
That sound is where the RH wheels touched the rumble strips.
Edit: posted at the same time. Some quick users here!
Mr.G
34
Re: Ferrari F14T
Ashamed :oops: #-o Thanks guys.
Rikhart
Rikhart
38
Re: Ferrari F14T
The cars rear looks absolutely planted from that video. All in all, I think Ferrari had a great start to 2014! I think all the signs point to the aero concept working ok, no major nasty surprises anywhere mechanically, very solid base to develop.
FlYiNgIcEmAn
FlYiNgIcEmAn
Re: Ferrari F14T
PABLOEING wrote:I see the front wing very "Basic" in comparation with the other cars.......¿near updates in this area?
Ferrari already said, that they will run in Jerez with a standard wing.
CBeck113
CBeck113
51
Re: Ferrari F14T
I was looking at the rear of the car in this FlowVis pic and had a couple of thoughts:
There's a very deep recess on the top of the diffuser, directly below the crash structure. Are they using this to help remove heat from the engine compartment? It would also do a good job at catching oil from a blown turbo, but that can't be its real purpose. In addition, they have tons of room back here below the bodywork - as if they were playing it safe for the first test. I don't think that the car in Melbourne will resemble this one too much. Come to think of it, I have the feeling that Ferrari, Mercedes and Red Bull are using a negative pressure system to evacuate the heat from their cars. Basically using lower pressure at the exits to pull the air out of the body work. This would explain the smaller openings up front and the rear openings in the lower area around the floor. McLaren & TR seem to force feed their radiators (= positive pressure), which works great up front where the radiators are, but can lead to hot spots where the air flow under the engine cover isn't all too good. Or I need a beer....
Squall
Squall
Re: R: Ferrari F14T
Pilatus wrote:Image
IR cameras, Merc style.
What are they used for?
Forza wrote:Jerez Test T01 - Day 1
What kind of sensors are these and what they measure? (strain gauge?)
I apologize for the maybe trivial questions for you
F1NAC
173
Re: Ferrari F14T
@squall these are infrared thermal cameras, they are using it for monitoring the tyre
CBeck113
CBeck113
51
Re: Ferrari F14T
@squall those stickers on teh rear suspension and crash structure are thermal sensors, which register the maximum temperature.
Pilatus
22
Re: Ferrari F14T
Flow separation.
Xwang
Xwang
29
Re: Ferrari F14T
Are they creating any kind of useful (or at the least the hope so) vortices in the point where the flux which comes from the upper side of the nose rejoins with the one which passes below it (exactly where the flux appears separated)?
