2014 British GP - Silverstone
FoxHound
55
Re: 2014 British GP - Silverstone
I believe Red Bull passed a couple Merc powered teams on the straights.
JET set
240
Vettel was faster than alonso with drs. There was a visual of their speeds in the fight. Maybe 16kph more with drs.
I know alonso was trying to set himself apart from vettel by listing his issues with his car, but he has a point. He put up a pretty good defense for quite some. In fact vettel should have gotten by sooner.
gray41
Every team testing this week?
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
beelsebob wrote:
n smikle wrote:
SectorOne wrote:That´s the thing. If Hamilton uses less fuel, people say he´s gonna have less in the tank.
And therefore have the same exact margins as Rosberg to finish the race but it´s always Rosberg that gets told he´s on the limit.
If the margins is the same you would expect both to get a somewhat equal amounts of radio messages about saving fuel.
Or am i missing something? Probably am.
I´ve only heard the usual from Hamilton´s radio saying "yea save a little bit in Tx"
But usually when it´s Rosberg it´s "ok fuel is critical, you need to save fuel"
The flaw in that reasoning is that the drivers target the last lap to use their targeted amount. This is not true. The target that the drivers see is a moving target and they driver drives as fast as he can until he the warnings come up.
For both driver's their fuel usuage when in fuel saving modes are similar as their driving style would be dictated by staying under the given target.
That's why we always see that 4% difference that stabilizes before the closing laps. The driver's are tempering their style to stay within the limit.
If Hamilton was fueled lighter he would get that call before Rosberg does.
No, he wouldn't - because again - he's using less fuel. The teams have an expected curve of fuel usage for the race. If you're above that curve, you'll get told you can use higher engine modes. If you're below it, you'll get told to fuel save. Nico gets told to fuel save more because he tends to dip below the curve more. He does that because his style requires that he uses a lot of fuel. When he drives fast, he uses a lot, he drives slower by not using as much. Meanwhile, something about Hamilton's style means that he can get the pace out of the car while driving fast still. The result is that he doesn't need to use lots of fuel to drive fast, and hence starts on less fuel, and doesn't get warned as much.
I disagree with you again that Hamilton starts with less fuel but let me use your logic...
According to you Hamilton's fuel usage delta is tighter (stricter) than Rosberg's (as he starts with less fuel)...
And since to our knowledge, Hamilton has never been warned to save fuel, Hamilton has been doing a better job at not only using less fuel at staying below that stricter target (more consistent).
Am I correct in saying that is what you were proposing?
So why does Rosberg suck so much at keeping below his fuel usage Delta that he is warned almost every race to get his stompers off the pedal?
beelsebob
beelsebob
85
n smikle wrote:No, he wouldn't - because again - he's using less fuel. The teams have an expected curve of fuel usage for the race. If you're above that curve, you'll get told you can use higher engine modes. If you're below it, you'll get told to fuel save. Nico gets told to fuel save more because he tends to dip below the curve more. He does that because his style requires that he uses a lot of fuel. When he drives fast, he uses a lot, he drives slower by not using as much. Meanwhile, something about Hamilton's style means that he can get the pace out of the car while driving fast still. The result is that he doesn't need to use lots of fuel to drive fast, and hence starts on less fuel, and doesn't get warned as much.
Am I correct in saying that is what you were proposing?[/quote]
You are. That looks like a pretty accurate summation of what I'm proposing.
That's a really good question. I think one possible explanation is above. Rosberg tends to get the "you're bingo fuel" warning in races he's leading - it could very well be that he puts his boot in to make sure he's ahead of DRS.
My suspicion is that the difference between Hamilton pushing and not pushing is that he tries to carry more speed through corners, and push the limits of the track, while the difference between Rosberg pushing and not pushing is that he tries to get his boot down on the accelerator earlier, and to brake later.
seahawk
I found the speed difference between Merc and the rest really huge. If they would go all-out for a whole race they would probably be lapping everybody except Williams.
Juzh
161
Just watched the race again. Ferrari was much faster in mid-range acceleration than the red bull, simply driving away from vetttel trough the first couple of gears, then when drs, slipstream and drag started to kick in vettel was gaining again, but at that time alonso was long gone on the straights. That's just an observable fact.
seahawk
What could be the reason? Better traction or more power?
Juzh
161
seahawk wrote:What could be the reason? Better traction or more power?
Definitely power. Be it ice or ers deployment. That ferrari was making short work of merc powered stuff into stowe at times during the race.
myurr
myurr
Or it could be that Alonso was ahead and therefore was putting his foot down earlier and was deliberately slow on the apex causing Vettel to hesitate. You see it in every race and it even has a name - the concertina effect - where cars close in the corners and spread out on the straights, as the lead car brakes and accelerates earlier and also as the distance covered at high speed is more than at low speed (presuming constant time between the cars).
If you look at the speed meters they are pretty evenly matched down the long straights until the Ferrari gets near its terminal velocity and then Red Bull keeps accelerating giving it a further 16 km/h or so. The commentators also made the point that Alonso was actively harvesting more power in the places where Vettel couldn't overtake and then deploying all of that power down the straights to try and counteract the DRS. This no doubt helped but if you look at the time that Vettel managed the overtake he was right on Alonso's gearbox coming out of the corner and didn't drop back that much through the mid range (as he would have done were he really at a significant power disadvantage) despite getting on the power at least a car length later.
zeph
^^^this^^^
FoxHound
55
Juzh wrote:Just watched the race again. Ferrari was much faster in mid-range acceleration than the red bull, simply driving away from vetttel trough the first couple of gears, then when drs, slipstream and drag started to kick in vettel was gaining again, but at that time alonso was long gone on the straights. That's just an observable fact.
I saw the concertina effect personally. Alonso varied his breaking on the apex visibly a few times, forcing Vettel either wide or to brake when he needn't.
JET set
max_speed
max_speed
whatever the case..alonso made donkey to run like a horse in yesterday's race. if someone followed the Fp1/Fp2 race pace of redbull was on par with merc's or better than rosberg's pace, he consistently lapped into 1.3o's while others were venturing into 1.40's range and yesterday too redbull was considerably faster than ferrari with drs it was gaining a lot on straight and as everyone has seen in corners only mercs can match the bulls. i knew tht vettel will pass alonso anyway anyone who has followed racing would have realized this. 7lap younger tyres on wide open circuit in a redbull , i dnt need to conclude it, but hats off to this guy alonso whose prime is getting wasted by ferrari. with all due respect to vettel , i think tht was hell kinda racing after long time , mercs duel havent delivered such quality racing till date now , rosberg just cant overtake hamilton even on a 7 lane carriageway. lets hope to see similar kind of racing in coming races barring mercs.
Juzh
161
@fh
Yes, few times. Majority of the time not so much. also, given both cars would indeed have more or less same bhp, concerina effect is nullified above 200kph and slipstream should start to overcome it, yet this didnt happen. ...
Reason: Removed personal comments
iotar__
Blaming malicious concertina effect for inability to overtake 2 s slower car, what else - brake testing? Forget overtaking, being overtaken and not give it even proper try. Add to overall lap pace: tyres (sliding) and traction out of the corners etc. Yes, I remember Perez in Cananda also using some "breaking techniques" because he had poor traction and different breaking points - remember when Ricciardo almost stopped and Perez couldn't do anything about it? Even after all those "tricks" Vettel ends right behind every lap.
Perhaps these were (F.A.) normal-modified defensive lines, you know the lines you do to avoid being overtaken? It's not like he's obliged to certain speed. To Vettel's baby cries (Lauda) let's add cries that he didn't just let him pass. Funniest quote of the season: "We had a two-second deficit in pace, so if we did a 13-lap show to keep him behind then it was welcome for the TV and for our sponsors. But after that we knew that we would lose the position." Pretty much - it was a forgone conclusion (nice Zen/samurai philosophy :-)).
BTW "Especially the lap when he overtook me he was three or four times off track". Now Lauda likes breaking all the rules but I don't remember defending "racing" when penalties gifted Hamilton easy win. Let's see the consistency and laugh if it happens again: in two cars duel you can do just about everything with going off track. I bet there will be hard warnings and penalties. No penalty for Raikkonen? You can't come back on track like that and cause dangerous high-speed accident, can you, what about Safety and Driving Standards? Big words can be switched on and off in F1 (Maldo doing the same 5 places, no one would even blink).
