Mercedes AMG F1 W03
DCren
Re: Mercedes AMG F1 W03
dren wrote:It's still a mystery where that top mini diffuser is getting its air from. It is probably coming up from the starter hole to make a semi double diffuser. I think the exhaust is expanding and covering the entire top of the diffuser, sort of like their side exit exhaust did last year. I expect a few more solutions to be tried out at the next test.
My thinking is that they are using the sidepod intake air and directing it there.That is what I was trying to demonstrate. Poorly I guess. :lol:
“It's not something that happens overnight. I kept saying that until mathematically things are impossible, I will keep fighting,” Michael Schumacher.
kilcoo316
kilcoo316
21
dren wrote:Right, if the rules allowed, you would blow into the diffuser. They didn't, so teams blew the edges. Both are of benefit.
Once again, no, you wouldn't.
Ferrari abandoned the exhaust blown diffuser in 1998 with the periscope exhausts to improve aero-balance between on and off throttle.
Luckily, I found this clip on youtube so you don't have to take my word for it:
[youtube]http://www.youtube.com/watch?v=Ui6EDypjZKQ[/youtube]
You *may* (like the McLaren in 2003) blown along the top of the diffuser (on the pressure surface) to aid entrainment. However you do not want to blow through the underside - that concept is decades old.
NewtonMeter
NewtonMeter
Seems like a massive amount of rake on the car:
Pic from the Merc website.
Nothing is foolproof to a sufficiently talented fool...
dren
228
It is, but they also didn't have the fancy computer control back then that they were using last year either. I don't know what the difference is in DF gained between the two. When were extra holes in the floor banned? (before the DD loophole)
I'll have to watch the youtube vid when I get home.
Honda!
FrukostScones
163
NewtonMeter wrote:Seems like a massive amount of rake on the car:
someone better tells them that it is not needed that much anymore, like Ferrari already learned it
DCren
dren, the FIA banned holes at the end of 2010.
Ganxxta
Ganxxta
diego1960 wrote:This year's Ferrari? If so could you provide a pic? I fear that again cooling is going to be a problem for Mercedes. On the other hand, they were able to complete 127 laps without issues so I guess it is not so important at the moment. What will happen though if Australia and Malaysia are way hotter than Barcelona is now?
Here you go... Seems that Ferraris color is not changing its color with heat like Mercs, but its definitely better to burn the color than to have such bubbles in it...
dren
228
I don't see how that would gain downforce though. You would want to help expand the air coming from under the car. If the mini diffuser isn't connected in some way to the main diffuser, it will not increase downforce on the car due to a venturi. Having gasses directed over the top of the diffuser will help, but then again you don't need a hole like that to do so.
Honda!
dren
228
I thought those were bubbles too, but they have them on both sides in the same places. So I'm not sure if they are bubbles or buldges due to packaging.
Honda!
DCren
Looks like rake to me.
aral
aral
26
manchild wrote:It is burning a lot just above the floor too. Definitely nothing to do with fumes apart perhaps that small bit on on top. It is the manifold that heats up the bodywork.
If you blow up the photo, you will see the severe overheating of the cf floor.
Ganxxta
Ganxxta
dren wrote:I thought those were bubbles too, but they have them on both sides in the same places. So I'm not sure if they are bubbles or buldges due to packaging.
After looking at it again, I think you are right, so sorry for that :oops:
dren
228
I did the same thing earlier in this long train of W03 posts :) no worries man.
Honda!
diego1960
I think they are bubbles, they look too random to be buldges due to packaging. This is the case unless they are absolutely identical on the other side.
"Being second is to be the first of the ones who lose." - Ayrton Senna
Forza Ferrari
Forza Ferrari
Would it make sense to do that?[/quote][/quote]
I don't get it: what are the two tubes and the end of the bodywork intended for? They should exite radiators heat, right?
So why should they channel this heat also from a different way?
Please guys, could you help me understand??
