SB15 wrote: ↑04 Aug 2025, 17:43
Well, If you're soo knowledgable what do you think is the problem? Since you said that my idea of "pull vs push works is simply terrible". Maybe you can explain without being so unnecessarily harsh and be respectful on what's really going on?
And if you think I'm saying one suspension is better than the other.. it's not. I'm saying in terms of how it's used for certain aero philosophies, there's a benefit and I said there was a reason why Adrian Newey, & now McLaren went with the same layout that's all I said.
No need to get angry.
If anyone here would actually know the problem, we would not be here. It is quite obvious, when Ferrari designed its car, they did not know this problem either. And only after testing, perhaps few races they started to understand. It is even possible, they still do not know exactly. So why would here anyone know???
We have like a billionth of the info needed to understand and know the problem, than they have. Not even mentioning the missing knowledge.
What we know is that between push and pull-rod suspension, there must be no such mechanical difference, that the engineers in F1 do not understand. That mechanical difference is in itself quite small as well.
CoG and small aerodynamics difference are usually more important when choosing between these two. Also, to redesign the suspension from one to the other is a huge cost, time, and takes away from other, lot more important development time and money. So they sometimes just stick with what they have.
The problem Ferrari and most F1 team have is to create car thats suspension works well with its floor. Current rules put a huge weight regarding performance on if you can run your car stable over the ground in regards to the floor, to maximise downforce. This is what RedBull got a lot better in the recent years. Remember other cars porpoising?
Ferrari specifically built new front and rear suspension for 2025. And they "simply" did not succeed in making the suspension work well with its floor and to keep the floor above a minimum height to protect their plank.
This is the most we can know.
We can only speculate if there is some very important knowledge they are missing regarding suspension, a new technology perhaps, or that their simulation is not perfect and what they design in the computer, does not work the same way on the track.
It can be that the whole car is not stiff enough, and they do not have the money and time now to redesign their monocoque, and their new rear suspension ought to help with that, with a moderate success.
Perhaps their tyre model is wrong in the simulation.
There were more than rumours that Mercedes used a flat rolling floor (instead of a coarse, more uneven) in their wind tunnel, that effed up all their measurements and simulations regarding ground effect, hence got their car wrong for years in this new area.
So who knows.
I mean, who in their right mind thinks here that they might know better than the actual Ferrari engineers who have the knowledge, the data, the actual hardware in their hands???
So just keep here everything light, never make statements that "we know" or this or that "obviously" better or worse... etc.
