Ced
Ced
f1316 wrote:
09 Sep 2021, 11:47
Ok thanks! I share the sentiment that being fast at Monza would be great, even if it comes with a 10 place penalty. Topping (or fighting for top spot) in Friday quali at Monza would be epic, even if it didn’t count as pole.
I presume grid penalties are applied to Sunday’s race not Saturday’s sprint, correct?
Yes
_cerber1
269
Ferrari engine 2014
lio007
320
More from the 2014-PU:
via @AlbertFabrega
_cerber1
269
+10 hp
ryaan2904
ryaan2904
36
See, this is what I was talking about. They've yet to even bring it on track and ffing AmuS knows what's going on.
Easily copied by merc in 22. :x :x :x
CFD Eyes of Sauron
Ced
Ced
ryaan2904 wrote:
14 Sep 2021, 17:57
Could someone explain "the whole electrical system will be converted from a 400 to 800 volt system" stuff ? And how it is a new tech ?
F1ern
F1ern
16
And the components will be smaller/lighter. Sounds good.
Ced
Ced
F1ern wrote:
14 Sep 2021, 18:37
What sort of advantage could it bring ?
LM10
LM10
122
ryaan2904 wrote:
14 Sep 2021, 17:57
AMuS most of the times have some insight because Michael Schmidt manages to get “juicy” stuff from engineers. But to have enough info to copy something in F1 is an entirely different story from having info such as that the electrical system will be converted from 400 to 800 volts. We’re talking about hugely complex technology.
Hoffman900
Hoffman900
220
I think from a PR perspective, I’d rather bring it in secret and hope it works.
Cyril’s comments about their horsepower and the snide comments about their performance are classic examples of that.
LaplacesDemon
LaplacesDemon
400V is archaic by modern standards and compared to the maximum limit of 1000V.
Formula E run 600V.
Also from
https://media.daimler.com/marsMediaSite ... d=44056073
In F1, we’re now close to 1,000 volts with the ERS battery. Modern electric road cars usually operate systems of up to 400 volts; however, the voltage will increase in the future and be closer to the voltage used in Formula One today.
mzso
mzso
66
Ced wrote:
14 Sep 2021, 18:27
Well, it ran on 400V and now it will be 800V. It's new because they made it now and weren't using it before. :)
A larger voltage inherently requires less conductors, so probably they're be saving some weight. What other advantages a 800V system would have I can't say.
LaplacesDemon
LaplacesDemon
For the same power higher voltage means lower current. Resistance losses increase with the square of current so increasing the voltage leads to higher ERS efficiency.
ryaan2904
ryaan2904
36
LaplacesDemon wrote:
14 Sep 2021, 18:57
Formula E run 600V.
Also from
Very interesting article. If mercs were supposedly at 1000 V already, I dont believe Ferrari would so behind so as to be at just 400 V. Which means either Daimler was bullshitting or AmuS is???
CFD Eyes of Sauron
648
14 Sep 2021, 21:13
not so
consider using a lower voltage for the same power as the original
eg halving the voltage means doubling the original current
this will require a quarter of the original armature resistance
so the resistance losses in the armature will be unchanged
