2025 Scuderia Ferrari F1 Team
dialtone
dialtone
139
Re: 2025 Scuderia Ferrari F1 Team
04 Aug 2025, 21:37
catent wrote:
04 Aug 2025, 21:28
It seems you are speculating quite a lot (unless you work for Ferrari).
What are these many flaws in the SF-25's construction?
The flaws are apparent to anyone with a working television.
You're on a roll here with the most incredible takes of the year lately.
Dee
Dee
atanatizante wrote:
04 Aug 2025, 16:55
venkyhere wrote:
03 Aug 2025, 14:07
Rikhart wrote:
03 Aug 2025, 13:44
2. He can't digest the fact that his muscle memory from decades of 'slam-the-brakes-with-steering-angle for as late corner entry as possible', is difficult to get rid of; and it pains him to see LeClerc (who doesn't have this problem) put the car on pole. It's a cruel reminder to him that if the car is in the right hands, it isn't that bad after all.
Before you post something regarding F1 driver skills, but mostly because your hate clouds your judgement, I`d recommend you see the reasons behind HAM`s struggles at Ferrari, from the point of view of a renowned specialist technical coach and mentor for open formula drivers:
Are we looking at the same thing?
All this technical analysis shows is that Hamilton cannot change his muscle memory or driving style in long corners, whereas Max, Lando and Charles have..
He also states that Lewis's self doubt at the moment comes from knowing that Max was the better driver in 2021 adding on to the fact that he hasn't adapted/can't adapt to the style that these cars need to perform on a qualy lap..
dialtone wrote:
04 Aug 2025, 21:45
04 Aug 2025, 21:37
catent wrote:
04 Aug 2025, 21:28
Ferrari has failed to finish within 20 seconds of the race winning car in most races this year and there's always an excuse from the team about "potential" and why the "next time" will be different.
Beware of T-Rex
ScuderiaLeo
Leclerc is staying in Budapest for a few more days as he's doing a Pirelli test on Wednesday with the SF-25.
dialtone
dialtone
139
04 Aug 2025, 21:49
See the forest from the trees. Ferrari has failed to finish within 20 seconds of the race winning car in most races this year and there's always an excuse about "potential" and why the "next time" will be different. The suspension of disbelief that some possess regarding the SF25 is simply incredible.
I see the forest. It's hard to take seriously anyone claiming that TV viewing is proof enough of "those issues".
Catent gave you an extremely reasonable response, there's not much more to say.
dialtone wrote:
04 Aug 2025, 21:53
04 Aug 2025, 21:49
I don't need to know how many inches of travel the damper has. In most weekends, 1 or more drivers are being told to lift and coast to manage one thing or another. In another weekend the car is DQ'd for plank wear. In another their pace drops off a cliff in the last part of the race (Spain, Canada, Hungary).
They finish 20+ seconds back on most weekends and they have no wins. What more needs to be said?
Beware of T-Rex
dialtone
dialtone
139
04 Aug 2025, 22:01
What more needs to be said about this car?
What more can be said about any other car then?
Honestly absolutely wild take for an engineering forum.
dialtone wrote:
04 Aug 2025, 22:11
Thread title.
Beware of T-Rex
dialtone
dialtone
139
04 Aug 2025, 22:14
dialtone wrote:
04 Aug 2025, 22:11
Thread title.
The thread title doesn't preclude pointing out low quality takes. This is still F1 Technical, not reddit or twitter.
EDIT: unless you mean I should just repost this in each team thread.
hollus
Gentlemen, what are you trying to achieve, exactly?
¡Puxa Sporting!
Leclerc might retire without becoming champion I fear...
They really need a huge Eureka moment for 2026 regs.
SB15 wrote:
04 Aug 2025, 17:53
Seanspeed wrote:
04 Aug 2025, 15:51
SB15 wrote:
04 Aug 2025, 01:02
That's what I'm not getting. James Allison said that the potential lap time gain was not worth it when it came to the development offset towards the 2026 car. To put it simply: "It wasn't worth the risk because it'll hinder time focused on the 2026 car" because they knew that they had to focus soo much on next year especially when it also have new engine regs.
James even admitted that they would get better results with the front pull-rod because of the aero benefits it has on the ground effect. The only reason I sent this was to show that the whole pull vs push-rod debate wasn't nonsense.
Now when it comes to Ferrari, come on, I think ever F1 pundit can very easily conclude that the rear suspension is the leading cause of the problems for the Scuderia..there's no denying it. Unless Ferrari does what Mercedes did with the W13, get rid of points of downforce via the floor so that the suspension can comply with the ground effect, which is unfortunate to say.
Ferrari's suspension definitely seems to be a big problem, but there's isn't much reason to believe the push vs pull aspect of it is the culprit specifically. Maybe I'm misunderstanding what point you're trying to make?
OH okay sorry, silly mistake! So I meant to add that how the Pull-rod or Push-rod is used for mechanical & aerodynamic purposes has its benefits depending on the regulation of car. One suspension is not better than the other, clearly that's really naive to think about.
To me, James was implying that for this particular generation of car, the pull-rod on the front suspension would've been beneficial for Mercedes due to how these ground effect cars prefer to be operated mechanically and aerodynamically. But, he doesn't see any reason to change it because while it would've worked, there was a new regulation period next year, so investing too much time into the 2025 car would've hindered the 2026 car's development.
So Mercedes seen a compromise and just stuck with concept from the W15 because that saved a lot of time, effort, resources and money.
I'm sorry that is not correct.
Push or pull is the same mechanical suspension-wise. It is for aerodynamic and packaging reasons why one is chosen over the other.
Hammerfist
Hammerfist
Dee wrote:
04 Aug 2025, 21:48
atanatizante wrote:
04 Aug 2025, 16:55
venkyhere wrote:
03 Aug 2025, 14:07
This lowerlaptime guy is just full of it to be honest. Technical coach but the way he speaks about the drivers it's like he's better than them and he likes to points out their little mistakes, like for example he was showing how Max was offf line while in the train following Lewis in Hungary and saying how his lines were terrible when all Max was doing is avoiding dirty air. Can't believe a supposed coach cannot understand that.
Also about LEwis believing Max was better in 21'. That is bollocks. He was down for the count and had to win 4 races in a row and he did it in style but Masi wouldn't have it.
At least he's better than Peter Windsor, that bloke spews so much nonsense and thinks everything in F1 has to do with short corners. There is just a lot of really bad content creators on youtube. These people have no shame in what they will say for clicks and not enough people call them out.
Rant over, sorry to be off topic.
McLarenHonda
Yeah this is becoming embarrassing for such a team of engineers…
Sergej
Months of PR about this magical suspension and they still are at the starting point.
