It is difficult to understand what they could be for, but given the way they are squeezed and deformed in the opening, they are probably not a designed outlet. Neither are they specifically aimed at a point where it could be of benefit. Therefore it looks as if they are a temporay solution to a problem, with little air pressure being involved.FORZA FERRARI wrote:
I don't get it: what are the two tubes and the end of the bodywork intended for? They should exite radiators heat, right?
So why should they channel this heat also from a different way?
Please guys, could you help me understand??
Vent for KERS? or maybe to duct hot air from around the troublesome exhaust manifolds?
