Ferrari F14T
Huntresa
Huntresa
Re: Ferrari F14T
muelte wrote:Not exactly an idea from RedBull (or a signal of cooling problems) It was there last year as well:
http://3.bp.blogspot.com/-CxCJm8M2fUU/U ... ustom).jpg
Perhaps something Red Bull should add tho :P
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F14T
He wasn't talking about the cooling vents, he was talking about the inward slant of the sidepods in the area of those advertisements.
atanatizante
129
Re: Ferrari F14T
scarbs wrote:Other Tech directors were fairly sure that Ferrari running water-to-air intercoolers and that Ferrari werent alone in that respect.
Not only the intercooler but also the engine radiator has the same solution and that`s the reason why Ferrari's new cooling system is more efficient, thus they could tighten up their sidepods ...
But there is a catch: if you look back in 2012 at Mercedes W02 (if I`m not wrong) they also have had a slick side-pods shape by adopting a double decked radiator solution (yeah just air-to-air) from that US company and they`ve got a lot of overheating problems, isn`t it?
And another issue of this water-to-air solution is that you end up with more weight ...
Jesus
miguelalvesreis
miguelalvesreis
Re: Ferrari F14T
Aren't engine radiators water/air? Normally?
The more weight or not, will depend upon packaging and length of pipes as well as thermal efficiency of the intercooler
muelte
muelte
Re: Ferrari F14T
My bad, I'm not native english speaker and didn't undestand properly... So it is the sidepod shape what he is talking about, right?
Re: Ferrari F14T
I noticed that the geometry of the suspension of the two cars is almost the same
Re: Ferrari F14T
They both have the shrouded driveshaft, so it isn't suprising because it requires a very specific geometry.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F14T
No worries mate. Yes he's referring to the sidepods just above the logo's. If you notice starting from the logo's at the floor the Sidepod slants towards the middle of the car. Last year there was a bit of an undercut there but this year it's overcut, which is a RB trait.
shelly
shelly
136
Re: Ferrari F14T
Forza wrote:Jerez - Pre-season Test 1 - Day 4
In thsi picture the trademark overcut shoulder shape of rb5-rb9 is more evident.
twitter: @armchair_aero
Froggolo
Froggolo
Re: Ferrari F14T
hello
have 2 thoughts to share with you
and i hope someone could give some useful answer
1) what is the goal in having a stepped chassis as highest as possible and having then the lowest nose concept design?
2) shouldn't be the nose tip by regulations ahead the front wing leading edge? because F14-t seems to be the only car
to have it inward the front wing leading edge
thankyou!
Relax, man. Have an elliptical drink or something® ( bhallg2k )
motobaleno
Re: Ferrari F14T
of course it is only pontless speculation...fantaF1 :)...but my impression till now is that F14T is not such fast but it could be the one with less drag at all...during the final part of the races this could get some surprise hopefully
muelte
muelte
Re: Ferrari F14T
Well, I suppose they expect to get lots of air going under the nose and to tea tray, just not mainly from the 'mouth' as before but also from around the nose cone. There are some drawings of this concept. Probably the high chassis is still better in achieving this, at least under their global design.
Anyway, I expect Ferrari to somehow copy Mercedes nose 'trick' to get a slightly higher and bigger mouth and get more airflow there.
motobaleno
Re: Ferrari F14T
Froggolo wrote: 2) shouldn't be the nose tip by regulations ahead the front wing leading edge? because F14-t seems to be the only car
thankyou!
mercedes also I would say
nacho
nacho
Re: Ferrari F14T
Any proof on the claims that Ferrari was very good on downshift's in Jerez? Seamless downshifts?
Re: Ferrari F14T
muelte wrote:Well, I suppose they expect to get lots of air going under the nose and to tea tray, just not mainly from the 'mouth' as before but also from around the nose cone. There are some drawings of this concept. Probably the high chassis is still better in achieving this, at least under their global design.
Allison said they are working on a more aggressive solution for Bahrain (chances are it could easily be something like Merc with him knowing how Lotus got around rules), so maybe they'll even show up with a third solution in Australia...
