Force India VJM10 Mercedes
Re: Force India VJM10 Mercedes
Front Comparison
FW17
171
Those barge boards are quiet forward. Has it been done before?
CLKGTR
CLKGTR
101
They start 430 mm behind the front wheel centerline, just like t-tray.
the EDGE
the EDGE
68
tpe wrote:
GPR-A wrote:
1158 wrote:Is this just a shadow? I haven't seen any other pics of that section from a different angle.
http://i162.photobucket.com/albums/t268 ... gzkxpt.jpg
That seems like a tunnel ! Intriguing!
I think that both Sauber and Renault have it. In Sauber it looks like it's covered though. Take a close look in the pictures. I asked the same thing in the other threads.
the shadow is not a tunnel, the is no floor in front of it, the grey that looks like part of the cars floor is actually the rooms floor
the front of the car's floor is raised at an angle and that is what is casting the shadow, and yes, this is also the same on the Renault, as to why I am not sure but Matt Sommers explains in his tech analysis on motorsport.com
ENGINE TUNER
ENGINE TUNER
25
I might be late but are these "nostrils" actually tunnels that feed the "s-duct" and exit in a blocked off for the reveal nose hump?
Would there be an advantage for taking the air at the front of the nose rather than under it?
yep, guess i was very late
ojlopez
ojlopez
Don't like it at all. The nose, even if it works as intended, is just hideous.
tpe wrote:So, they have a tunnel in the sidepods. I can only think 2 reasons:
a. Cooling (?)
b. Feed the defuser.
Unless someone else have a better educated guess on them....
Why not both?
roon wrote:-Almost full-width sidepods, as holm86 alluded to.
-Front wing clearly delineated between sections in front of wheel and sections inboard-of. Resultingly, the outboard vortex tunnel is wider.
https://i.imgur.com/5mYdMDKh.jpg
Nice catch.
charly0418
charly0418
In the AMUS interview Andy Green says they're getting rid of the S-Duct for sure. With the amount of air they're getting with the new nose there's no need for it
FrukostScones
163
http://www.auto-motor-und-sport.de/form ... 24280.html
Andy Green sounds very optimistic.
a. Cooling (?)
Cooling, obviously. Most likely a different, non-standard radiator setup
zac510
zac510
22
You guys sure madly want to see a tunnel somewhere.
To my eyecrometer the wheelbase looks shorter (than the other cars so far this year) and to achieve that they've made the sidepods a bit wider.
It's not a tunnel, they're not tunnels on the other cars either, they're just bellmouths before the throat under the floor - a consequence of a wider floor, bigger diffuser and larger bargeboards meaning they need to feed more clean air under there.
Quantum
FrukostScones wrote: https://imgr4.auto-motor-und-sport.de/F ... 008476.jpg
The serration on the turning vane is not uniform, unless there is some optical illusion taking place.
Any reason why? Surely you'd want a uniform series, or there will be uneven airflow....unless that's the objective?
"Interplay of triads"
The diffuser is very strange, at least in the sense that the edges curve outward instead of trying to form a confined area around the diffuser ramp. Most diffusers are shaped like this /--|--|--\
