2017 Italian Grand Prix - Monza, 1-3 September
Restomaniac
Restomaniac
Re: 2017 Italian Grand Prix - Monza, 1-3 September
Ted Kravitz has just said that Mercedes have decided to voluntarily decided to stick to the new 0.9l even though they can go to 1.2l as they are on engines pre Monza. They also ran to 0.9l in Spa when Ferrari were at 1.2l.
That cannot be right surely as that means they gave up an advantage and were STILL faster than Ferrari. At least I hope for Ferrari's sake it's not true.
Restomaniac
Restomaniac
Chene_Mostert wrote:
01 Sep 2017, 10:16
Restomaniac wrote:
01 Sep 2017, 10:13
01 Sep 2017, 10:06
Yes, I think you are. . Or maybe you and some of the other from the 2014 brigade.
I've been watching F1 for far, far longer than since 2014. Sorry.
Apology accepted.
The only aplology I offered you was for correcting your obvious incorrect assumption. Just for clarification.
Glad you felt the need to thank me for pointing out your cock up O:)
Chene_Mostert
-2
Restomaniac wrote:
01 Sep 2017, 10:18
Can we trust anything from ted or Toto?
"Science at its best is an open-minded method of inquiry, not a belief system." - Rupert Sheldrake
Restomaniac
Restomaniac
01 Sep 2017, 10:24
Restomaniac wrote:
01 Sep 2017, 10:18
Now that's the question. I got the impression that Paul Di Resta wasn't convinced.
Phil
66
Restomaniac wrote:
01 Sep 2017, 10:18
AMuS reported this all along. Didn't quite believe it myself, but seems to be true. I somehow expect Mercedes to be dominant in Monza. There are a couple of reasons that worked against them in Spa I feel.
1.) They traded-off lap time for straight line speed. According to Toto, this cost them 2 tenths in lap time.
2.) IMO Mercedes was limited by tire performance. The car optimally worked on the softs - the US was probably too sensitive for their car over the entire long lap and loads even though Pirelli mandated quite high pressures which usually suit Mercedes
3.) I don't think Ferrari could have driven much faster in clean air than what Hamilton set. Mercedes were a bit in a pickle - they needed to pit first to avoid the undercut which made them more vulnerable for a 1-stop on the softs. So they needed the right pace to make it to the end, but quick enough not to let Vettel into DRS.
I think Monza will suit them better, given it's SS, S and M territory.
#Team44 supporter
outsid3r
Restomaniac wrote:
01 Sep 2017, 10:28
01 Sep 2017, 10:24
Restomaniac wrote:
01 Sep 2017, 10:18
Someone should ask Merc for one good reason why they prematurely introduced a new engine then :)
Restomaniac
Restomaniac
outsid3r wrote:
01 Sep 2017, 10:36
Restomaniac wrote:
01 Sep 2017, 10:28
01 Sep 2017, 10:24
Indeed.
Phil
66
Maybe to give them the option that they can use more oil if they deem it necessary...
#Team44 supporter
atanatizante
129
Is it me or Merc drivers tested between a 4 and 5 elements FW?
Jesus
NathanOlder
outsid3r wrote:
01 Sep 2017, 10:36
Restomaniac wrote:
01 Sep 2017, 10:28
01 Sep 2017, 10:24
Is it not as simple as them wanting a fresh engine for Spa ?
GoLandoGo
Lewis v2.0
King George has arrived.
Phil
66
NathanOlder wrote:
01 Sep 2017, 11:18
I think because only 4 engines are allowed to be used this year, it would make more sense to wait and introduce the engine later as Ferrari is doing. Still, it's weird that Mercedes jumped the gun if not to make use of the 1.2 oil directive. Then again, to say they will only use the new directive makes sense - anything else would cause a bit of a controversy and criticism, especially if they go on and dominate on certain tracks. They might try to use 0.9, but have some special modes available if they deem it necessary.
On the other hand, Ferrari may find a bigger gain by waiting a little longer and have more time for their final update...
#Team44 supporter
Restomaniac
Restomaniac
Phil wrote:
01 Sep 2017, 11:29
NathanOlder wrote:
01 Sep 2017, 11:18
Its swings and roundabout though. Aren't Ferrari now having to used all their turbochargers on rotation now where are Mercedes have newly unboxed ones to come (I know a new TC isn't on the same level as a new ICE)?
It would seem teams are going to be balancing like mad for the rest of the season.
ChrisDanger
ChrisDanger
26
Phil
66
Yeah... I am actually very interested to see how Ferrari will deal with it. Surely they will have to take a penalty at some point, unless they deem the old units still usable? ...
#Team44 supporter
Schuttelberg
The Halo's make the helmet design non existent for the viewers.
