2026 Aerodynamic & Chassis Regulations
dren
228
Re: 2026 Aerodynamic & Chassis Regulations
The rake concept also got the front wing closer to the ground.
Honda!
basti313
basti313
32
jjn9128 wrote:
19 Aug 2025, 11:38
basti313 wrote:
19 Aug 2025, 11:35
Did you miss ground effect? Rake or ground clearance of any kind kills the venturi tunnel geometry.
Right... and a diffuser isn't ground effect? How does it "kill" a tunnel underbody but not a flat underbody? What are the mechanism differences? You still create low pressure under the car, you still need to seal the floor edge ingress, you still need to prevent tyre wake coming into the floor. So what mechanisms are at play that you so confidently say "rake = more downforce" for a flat floor car?
Sounds like a exam. What do you want to tell us?
To answer directly...in a venturi tunnel, rake causes two major problems:
Tunnel geometry: The venturi is designed for flow parallel to the ground. Tilt it and you effectively close down the rear expansion zone. Instead of smooth pressure recovery, you get earlier separation.
Uneven throat heights: Raising the rear increases the average tunnel cross-section. That reduces the speed-up in the throat (less suction), i.e. it chokes off the ground effect you’re trying to maximize.
I do not think the point on the floor sealing is similar as you say, but I do not know if it makes sense to go into this detail. Maybe you could say what your relevance to 26 is that you relate to?
Don`t russel the hamster!
karana
karana
Here is what Willem Toet wrote in a comment under his article "How motorsport diffusers work" on Linkedin 5 years ago:
Red Bull were one of the first to run high rake and it is not about achieving higher downforce. From my article about how diffusers work you will see that you can get more stable diffuser performance over a reasonable range of heights with more expansion. But that is not why RB went for high rake. All teams tested higher rake in their wind tunnels and saw no gains in downforce. What you gain is reduced aero balance change with speed. Normally a car would increase aero balance if you push both front and rear heights down in parallel. With more rake, you can run softer rear springs. A low speed the rear is very high but the rules force all parts to be aligned around the floor planes. That means high rake will push the front wing down into ground effect. More front downforce at low speed. At high speed the rear is pushed down much more than the front which reduces rake on everything (lowers drag) and also pushes the front wing up relative to the height at the front wheels (because the rear moves so much). Red Bull are not the car with the most rake any more. All barge teams have barge boards and vortex generators on the floor with this level of complexity.
jjn9128
785
dren wrote:
19 Aug 2025, 14:07
This.
karana wrote:
19 Aug 2025, 18:45
And this.
#aerogandalf
vorticism
vorticism
449
vorticism wrote:
14 Aug 2025, 18:24
Per issue 13:
-There are front wing and rear wing versions of the adjuster system (FWAS & RWAS).
-FW: up to 3 profiles, one or two of the rearmost of which can comprise the FWAS.
-RW: up to 3 profiles, the rearmost of which can comprise the RWAS.
-If using 2 profiles in the FWAS they can rotate along their own axis, with a max deviation of 30 mm for the “Primary Flap” and 60mm for the “Secondary Flap.”
-FWAS flap pivot axis can be angled up to 30 deg from transverse, meaing (I take it) there can be one continuous flap with a 0* axis (like current RW DRS) or one flap per side with up to a 30* axis (like current FW flaps)
-FWAS can have one or two actuators, one centrally with a fairing, or one per side faired with the FW pylons, and be driven electrically (new) or hydraulically
-Two positions like DRS: “corner mode” and “straight-line mode” with a maximum 400 ms transition time.
-There will still be “activation zones” defined by the FIA similar to the current DRS zones--presumably comprising any applicable corners and straights per track.
All told I see one major potential differentiation available across teams: a FWAS that has either one, two, or four rotating flaps. Another less visible one will be the choice to use a hydraulic piston or an electromechanical actuator.
Clarification on this: if the RW has 2 elements, the rearmost element (the flap) is to be used for the RWAS just like the current DRS actuation. If the RW has 3 elements, both of the rearmost elements are considered as flaps and must move together as the RWAS.
It's been a while since the FIA permitted variable numbers of FW elements and even longer since they permitted variable numbers of RW elements. Seems like this is returning with the "up to" verbiage. I'm not sure if anyone will choose a single plane Indy 500 front or rear wing with no moving flaps for Monza, but it seems like the choice is being offered. Circuit to circuit this could be an obvious changing area of the cars--two or three element wings. Or will there always be an advantage to using more elements over fewer? Beam wing choices over the past four years suggest not.
jjn9128 wrote:
19 Aug 2025, 08:02
And why you think raising the rear ride height would result in "free downforce" and how you can explain the low rake Merc winning 8 WCCs in a row if it wasn't a downforce monster!?
Free as in easily accessible. Never claimed the Merc W series cars were low DF; what made you read this?
jjn9128 wrote:
19 Aug 2025, 08:02
What it is about the past, current and future regs which encourages or precludes the use of rake in the concept design?!
The 2022 concept was effectively a skirted tunnel with a prescribed location for the venturi neck, what some call the kick. Recall the first year spec had the floor edges at the same height as the reference plane--about as close as they could get to full contact skirts. Cleverly RB took that one step further with what I at the time coined their ice skates i.e. their interpretation of the edge wing allowance, which they used not as a wing but as a metal strake beneath the floor edge that did somewhat act like an actual skirt and as a stop. The prescribed location of the neck/throat of the venturi was in a region just ahead of the fronts of the rear tyres i.e. pretty far back, nearer to the rear axle than the center of the car. Rake angle would have proportionally lifted that point off the ground and would have compromised the skirt seal and reduced the pressure ratio the tunnel could achieve.
From what you wrote, we agree that rake was used in F1 pre '22 (not that it was debatable), and I'm saying I expect it to return. Are you saying it won't?
jjn9128
785
vorticism wrote:
19 Aug 2025, 22:36
... I'm saying I expect it to return. Are you saying it won't?
I'm not saying anything, in the end it will be the result of a given teams car philosophy. All I'm asking for is some critical thinking as to why rake is used on an f1 car - the mechanisms at play, the fact the best teams at raking their car pre-22 had quite flexible bibs and planks to really make it work, the fact that floor (and other parts of the car) optimization was different between the high and low rake concepts. Then consider what it is about the 26 regs which will mean rake is desirable? What is the desired flowfield aim of each concept and how might that be achieved on a 26 car?
Then consider why statements like the below are so incredibly inaccurate. Why is moving your diffuser kick (the region of greatest suction on the floor) out of ground effect "free floor downforce"? Why is it that you think flat floor = must have rake?
vorticism wrote:
18 Aug 2025, 21:34
It's free floor DF so I'm expecting it.
#aerogandalf
Holm86
261
jjn9128 wrote:
20 Aug 2025, 10:08
vorticism wrote:
19 Aug 2025, 22:36
vorticism wrote:
18 Aug 2025, 21:34
Rake can increase the effect of the diffuser, but only if you're able to seal the diffuser from rear tire squirt effectively enough, according to this article, the new inward flowing bargeboards makes tire wake difficult to control, so I don't expect high rake designs, not in the beginning of these regulations anyway
https://www.raceteq.com/articles/2025/0 ... mula-1-car
vorticism
vorticism
449
Bargeboard options for everyone’s head CFD. “Up to” 3 x, 3 y, 3 z fit inside a narrow box (~2” thick) from which nothing behind it may be visible when viewed from the side.
jjn9128 wrote:
20 Aug 2025, 10:08
vorticism wrote:
19 Aug 2025, 22:36
vorticism wrote:
18 Aug 2025, 21:34
Well, who calls you incredibly inaccurate matters. If Willem logs in to castigate me, my ears will perk up. I explained what I meant by free yet it went unquoted. Downforce from rake is not strictly a matter of the diffuser and its distance to the ground, in this case, the average range of static height variation of ~50mm (half a rain light--useful dimension!) at the rear of the cars apparent when comparing pre-'22 cars f.e. 2019 RB/Sauber/Ferrari/Mclaren/Renault vs Merc, in other words, the choice of avg ~3* of rake vs ~1.5* across the season.
Would you claim there’s no advantage in ’26 to lowering the front wing? What would your favorite LinkedIn authors say? Will using the entire car as an aeroelastic platform (via the suspension) with maximized rake displacement across the operating speed window be less advantageous than it was? And it may be less advantageous owing to the effects the active aero may have (allowing higher DF yet less or no equivalent drag penalty on the straights) along with the larger diffuser. Would you go so far as to suggest that zero or positive rake (nose up) may be more advantageous?
Tangent for anyone interested, as it relates to lore about Merc that’s come up recently on this forum: I’ve measured 1-2* of rake for pre-2022 Mercs and 2-4* of rake for its contemporaries. The W10 (2019) wheelbase in photos measured about 80mm (+/- 20mm) longer than the RB15, this on a car with a, per Wikipedia, 3730 mm wheelbase (W10) i.e. ~2% longer than the RB15. It wasn’t an excessively long nor a zero rake car, relatively speaking.
Holm86 wrote:
20 Aug 2025, 15:19
...the new inward flowing bargeboards makes tire wake difficult to control, so I don't expect high rake designs, not in the beginning of these regulations anyway
[image]
Part of the '26 concept must have this in mind, owing to where they chose to place this new, major aero implement. I see it as adding a high pressure field above the front floor corner. If the wake is a problem though, it makes me think we might see teams try to make these things more outwashing by various means f.e. a small forward portion of the bargeboard ("floor board") could be situated in opposition to the majority of it. Lower item below.
vorticism wrote:
09 Aug 2025, 17:28
...it could also permit forms similar to the current edge wings, rotated 90*.
Upper two items in the sketch above. The diffuser strakes must fit inside a straight box (see linked post), although it's 40mm wide. 1 x, 2 y, 1 z, leaves only a few development paths.
CAEdevice
55
In my humble opinion — based on MVRC 2025, which already mirrors the upcoming 2026 F1 regulations — a rake-oriented setup seems unlikely. There are several reasons for this:
1. the new cars are expected to be rear downforce limited
2. the central section of the front wing will primarily serve to channel airflow under the floor
3. design freedom to effectively seal the outer floor edges will be very limited
McLarenHonda
One thing that I hope becomes better is the slipstream effect!
The 2022 rules tried solving downforce loss through the corners yet ended up destroying the slipstream effect which in turns has produced a ton of boring races like Baku! I mean you can’t have 1km straight, be within 0,5sec and still being unable to pass…
But looking at the 2026 rules the low downforce mode which will automatically be activated on the straights will probably evaporate any slipstream effect produced from the new rules!
Also Autoracer.it is saying that cars are already 3 seconds faster than the FIA estimates! Anyone able to read the full article?
mzso
mzso
76
McLarenHonda wrote:
25 Sep 2025, 14:18
I don't think that's the problem. The new regs worked, for around half a season. By the end of it Vettel already complained that following is already harder. Of course in their infinite wisdom, the task force lead by Brawn was disbanded by this time and the FIA didn't push through any regs to reverse the is process. So nowadays we're back to where we were in 2020...
It looks with its baggage of political, corrupt filth F1 can only gravitate toward garbage racing.
f1isgood
f1isgood
mzso wrote:
06 Oct 2025, 14:05
McLarenHonda wrote:
25 Sep 2025, 14:18
The primary way to have good racing is having large pace differential. Unless there's that there's nothing much you can do. Also racing is good if cars all have different strengths. In 2022 racing at the top was fun only because RB and Ferrari had different strengths and weaknesses and were basically about par with respect to pace.
mzso
mzso
76
f1isgood wrote:
06 Oct 2025, 14:34
This is certainly not true. Faster cars will just qualify in the front and fly away into the distance.
f1isgood
f1isgood
mzso wrote:
06 Oct 2025, 14:52
f1isgood wrote:
06 Oct 2025, 14:34
If all cars are close then there will be no racing as there is no pace differential to close the gap let alone pass. Cars need to have different points of strengths and weaknesses to promote good racing if they are evenly matched. Otherwise it is simply qualification and then race to victory, just like this year.
Also, without dirty air, there is no slipstream effect either that can be felt. While easier to follow in high speed corners, it still has it's own disadvantages.
Strategy could play a role but that's rare and most people don't care about what happens in the midfield.
Red Bull pulled me out of my sabbatical and hired me to replace Adrian Newey, so here’s the 2026 RB I sketched up last night. It’s not exactly compliant with the 2026 rules; it’s more of a 2029 concept. But this thread will help me catch up with the 2026 regs (though it’s hard to keep focus with all those beautiful Vorticism drawings & co), plus, like Adrian Newey, I focused on the internal layout and packaging first.
(it's just a gift for a friend)
