Ferrari F14T
langwadt
langwadt
Re: Ferrari F14T
.poz wrote:Are silver cables permitted ? Silver conducts electricity slightly better than copper
well, silver is ~5% better but it is ~15 heavier, aluminium is ~twice the resistance of copper but only ~30% of the weight
diemaster
diemaster
Re: Ferrari F14T
http://www.mezzotech.com/Applications.a ... -radiators
cooling partner of Ferrari
their location in Florida
areas of application:
Aerospace Industry
High Performance Automotive Racing
Department of Defense
Commercial Shell-and-Tube Heat Exchangers
http://www.auto-motor-und-sport.de/form ... 51398.html
Owen.C93
Owen.C93
177
Re: Ferrari F14T
diemaster wrote:http://www.mezzotech.com/Applications.a ... -radiators
Aerospace Industry
http://www.mezzotech.com/portals/0/imag ... ors-lg.png
Looks like the Sauber actually.
nhojekim
nhojekim
Re: Ferrari F14T
Silver cables heat up pretty easily. So I dont think it woul be smart to use it.
bill shoe
bill shoe
151
Re: Ferrari F14T
Another issue is contact resistance between the cable itself and the various connectors/connections at the ends. I think I heard something about U.S. houses going to aluminum wiring during WWII copper scarcity, but having fire problems due to increased contact resistance at the ends of the wiring. There's a lot to think about when you have wires transferring 200 hp of electrical energy in a tiny, light car.
Re: Ferrari F14T
Aluminium electrical conductors are ready for series applications already since 2008-BMW has his Battery leads from back to the front of the car in Aluminium for weight saving .(BMW 7series since 2009)
automotive Validation is a tough call-including 300h of saltspray testing ,Vibration etc.. the connectors are sonic welded to the leads...
shelly
shelly
136
Re: Ferrari F14T
From this picture on tobias gruener twitter:
https://twitter.com/tgruener/status/433560163497152513 it is very easy to see tha change in shape between f138 and f14t, with the latter using rbr5-9 typical wide and overcut shape
twitter: @armchair_aero
langwadt
langwadt
Re: Ferrari F14T
The issue with the aluminium wiring was that if it isn't done just right it get lose and corrodes
don't think it would be an issue in an F1 car
the electricity companies use aluminium wires in some places, the low weight means you can hand a thicker cable from
the same pole and it is cheaper too
Gridlock
30
Re: Ferrari F14T
Mr.G wrote: All the wiring depends on how the MGUs are build.If they have their own AC/DC converters then the link between MGUs and ES will be DC. If they are pure AC the linking will be AC too. I think they are running the first option.
Jerez Ted's Notebook, day two - AC (RenaultSport). Converters in the ES, which IIRC were a big part of the thermal issue.
#58
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F14T
GA once again on the F14 T.
via AutoSport
eslam1986
eslam1986
Re: Ferrari F14T
from Lorenzo De Luca : Ferrari F14 use Ttitanium microtube heat exchanger with two tenths of a millimeter internal diameter used to cool the V6 059/3, capable of ensuring the necessary cooling with much smaller dimensions.
eslam1986
eslam1986
Re: Ferrari F14T
Ferrari engineers are studying a system which allows to cool down the V6 taking advantage of a feature of the engines 2014: direct injection. Basically, when engine power is not required, there is absolutely no fuel and no ignition of the spark plug: air enters only through pressure from the turbo.This lead to a cooling of the piston crown, the cylinder and the combustion chamber without having to use, as they did with V8, a small amount of fuel.
trinidefender
trinidefender
318
Re: Ferrari F14T
eslam1986 wrote:Ferrari engineers are studying a system which allows to cool down the V6 taking advantage of a feature of the engines 2014: direct injection. Basically, when engine power is not required, there is absolutely no fuel and no ignition of the spark plug: air enters only through pressure from the turbo.This lead to a cooling of the piston crown, the cylinder and the combustion chamber without having to use, as they did with V8, a small amount of fuel.
I'm fairly sure all the engine manufacturers are doing this. None of them want to burn fuel they do not have and as well as that turn that fuel into heat in the engine. It is a fairly basic principle so for now it would be safe to assume all the engines do this
Holm86
254
Re: Ferrari F14T
eslam1986 wrote:from Lorenzo De Luca : Ferrari F14 use Ttitanium microtube heat exchanger with two tenths of a millimeter internal diameter used to cool the V6 059/3, capable of ensuring the necessary cooling with much smaller dimensions.
https://lh6.googleusercontent.com/-_xQL ... lheat2.png
This could be related to the "exotic materials" there was talks about on the closed reveal of the engine.
Holm86
254
Re: Ferrari F14T
I dont see anything special or innovative in cutting the fuel injection either. To me its just logical to do so. And if they are doing something it could be what i has been talking about for some time which is keeping the throttle bodies open when the driver is off throttle. Eccentially a sort of cold blowing. This would have some advantages which I've written about in other threads.
