Mercedes AMG F1 W05
Re: Mercedes AMG F1 W05
raising the nose doesn't necessarily increase downforce at the rear.
240
mclaren has a flatter front suspension angle.
JimClarkFan
JimClarkFan
27
Need to see the back comparison, the rear body works seems better packaged in Merc. The merc diffuser is different too
diego.liv
diego.liv
From AMuS article http://www.auto-motor-und-sport.de/form ... 87131.html
But while the Dane [Kevin] was traveling with super soft tires, Rosberg handed in his qualifying attempt the mixture "soft". And there have been even better. "I have made a mistake in my fastest lap in the last corner, we had a conservative cooling specification has it cost what output, and I have omitted the planned third attempt with soft tires."
SO, he was pushing for even a better time, but most important, the cooling spec chosen
smlbstcbr
smlbstcbr
theformula wrote:Just put the question to scarbs. He said the purpose would be to offset the understeer by creating more front DF.
However, I still don't understand why they would want to do this because surely they would want all the DF they can get at the rear at this stage of the season?
But how would they turn around the corners if the rear is too "heavy"?
Per
Per
emmepi27 wrote:Differences between two of five (?) solution tested by Mercedes
https://pbs.twimg.com/media/BhFtT6rCEAAsEuM.jpg:large
There's a small difference in perspective between these pics and it makes a huge difference when studying a round shape like the sidepods. So I think the difference looks exaggerated here.
240
Anyone notice that the mercedes unit has a much louder turbo noise than the other cars?
Especially when compared to the Renault unit.
I have a feeling it's the most powerful, but chances are the Renault unit may be most efficient.
Lycoming
Lycoming
106
ringo wrote:I have a feeling it's the most powerful, but chances are the Renault unit may be most efficient.
But wait... with a fuel flow limit, aren't those the same thing?
Kai
Kai
Fuel is restricted to 100L per hour flow. Races go for over an hour and the cars are limited to 100L in total.
myurr
myurr
ringo wrote:Anyone notice that the mercedes unit has a much louder turbo noise than the other cars?
With the turbo now being part of the, in Renault's case, troubled electrical system it's more likely that Renault are just running at a lower boost level at the moment.
henra
henra
tranquility2k4 wrote:The translation of the articles on auto und motor sport can often be misleading and it may be that although the nose is lowered at some point, it may not be right at the front or it may be a different design at the front such that they still get as much airflow under the nose?
I could also only imagine a bit of misunderstanding or translation problem.
I could imagine it was more meant in a sense of a shorter + steeper nose while keeping the same cross section underneath. That might look like a lower nose but not be actually lower.
Really absolutely lowering the nose seems definitely counter- intuitive and I can't imagine them doing that.
Steeper+shorter plus maybe a bit rounded off upper + lower edges might be worth investigating since it could reduce the width of the high pressure area in front of the nose and moving it a bit to the rear, thereby allowing more airflow to pass alongside the nose which would otherwise be more displaced to the sides. This could still help the rear end of the car.
theformula
ringo wrote:mclaren has a flatter front suspension angle.
McLaren has flatter suspension angle since their whole chassis is lower than need be.
Hamilton's blessed with an ability to make a car do pretty much anything he wants - Mark Hughes
atanatizante
126
Here is a translation from AMuS article, where Paul Hembery said he is surprised that 2014 Pirelli tyres are hotter on the front rather than rear ...
And that`s why MB are bringing a new FW but if that`s the case why the new nose will be lower?
http://translate.google.ro/translate?hl ... &sandbox=1
Jesus
henra
henra
atanatizante wrote: Here is a translation from AMuS article, where Paul Hembery said he is surprised that 2014 Pirelli tyres are hotter on the front rather than rear ...
Indeed he confirms that the colder temps on the Rear are due to lack of Rear DF.
He assumes the Teams will be able to correct this to some extent over the season, so this also confirms the ongoing battle for Rear DF of the Teams. Therefore I would be surprised by Merc actually lowering the nose. Shortening, maybe but lowering: I doubt it.
The Pj
The Pj
-3
Airfoil with the sensor (speed over ground sensor and slip angle sensor unit?) under the body..
:D
