Red Bull RB10 Renault
djos
113
Re: Red Bull RB10 Renault
I would have thought a Titanium Gearbox case would act as a giant heatsink for the turbo and reduce cooling requirements if this is the case?
"In downforce we trust"
DarkJRO
Am i Wrong, or is the enginecover only one big part?
via AMuS
Greetings
Dark JRO
aleks_ader
90
DarkJRO wrote:
Blackout wrote:The gearbox casing's shape is very interesting. You can see it around 0:28 in front of RIC when he's walking. It hosts the Turbo which seem to lie very low between the engine and the G-box, not on top of the latter.
Like some Indy cars...
http://www.servimg.com/image_preview.ph ... u=14795526
Indeed, this looks great. Must wokr for a very low COG.
Could this be the reason for those temperature issues? I mean the turbo should get very hot and the gear box right next to it won't like cooking temperatures, does it? perhaps the turbo even gets hoter than renault said to RBR?
So the handmade cooling vents in testing could have been for the gearbox? (could explain, why they were only on one side)
Could they move the clutch even more backwards behind turbo or they could squeeze it into tight otherwise regulated mandated gearbox attach area underneath turbo?
EDIT 1: + WHERE the MGU-H goes? Isnt that to low? Or they produce very short Electric motor like Merc did?
2014 Australian Grand Prix - Thursday, 13.03.2014
timbo
timbo
113
Shouldn't it all be the same for all Renault teams? Or RBR could have turbine/compressor where they exactly want?
basti313
basti313
It must be the same part by the rules. And I guess it must also be the same transmission, so it has to be in the same spot for all Renault teams.
So still no picture of the front wing with cameras...
Don`t russel the hamster!
The engine/gearbox mounting points:
Actually the upper mointing points are relatively high compared to the V8 so the Turbo is'nt that low... it sits a bit low though; directly above the clutch (which is higher than in the V8 as you know). The clutch area looks smaller than the real one in the 3d renders due to the angle.
timbo
timbo
113
So apparently there isn't a big difference in turbo positioning between manufacturers, and all Renault teams must have a gearbox case with a similar cutout.
FrukostScones
163
No wonder it goes kaputt.
Vettel Maggot
Vettel Maggot
Love the attention to detail, I assume the purple dots all around the brake assembly are so the mechanics don't miss putting a screw in. Little things all add up don't they?
Jef Patat
Jef Patat
Vettel Maggot wrote:Love the attention to detail, I assume the purple dots all around the brake assembly are so the mechanics don't miss putting a screw in. Little things all add up don't they?
it's not obvious but you must be kidding
blokkie
blokkie
+1 .. he must be .. it's to obvious :)
dren
227
Are those sensors on the tie rods? Do most teams monitor the steering angle?
Honda!
Owen.C93
Owen.C93
177
Getting close to FP1 with no signs of camera pods. This is serious business guys.
cubejam
cubejam
19
No camera pods on the Red Bull nose, but there's a hole in the nose now.
