Mercedes AMG F1 W03
issues4
issues4
Re: Mercedes AMG F1 W03
The_Truth wrote:
george1981 wrote:On the subject of tyre degradation. Mercedes have said that the the temperatures at Barcelona are low and due to the amount of testing the track has a lot more rubber down than there would be at a GP weekend, so no conclusions can be drawn. However I'm slightly pessimistic about this. Although the absolute figures for degradation won't be the same I'm sure the pattern is correct, the Mercedes has worse tyre degradation than the Lotus and the Redbull. Can someone with superior knowledge of tyre degradation put my mind at rest?
This could help you :)
http://abulafiaf1.wordpress.com/2012/03 ... 012-day-7/
=D> :D :twisted:
turnerf1
turnerf1
To be honest i don't think the tires will be a huge issue. If you look at that graph merc have about the same drop off as the rest of the field in the irst few laps on them. Also when i looked at it it seems that mercs lap times steadied out more that of Redbull or the Ferrari camp.
the official press release tells us : car length is 4800mm .so we can decifer the wheelbase from that assuming both front and rear overhangs are mandated by the regs ? (with a little uncertainty with regard to nose cone length....
Tozza Mazza
marcush. wrote:the official press release tells us : car length is 4800mm .so we can decifer the wheelbase from that assuming both front and rear overhangs are mandated by the regs ? (with a little uncertainty with regard to nose cone length....
It's not 4800mm, WAY too short, maybe W02 was that short, but that kind of length is approximate of 2008 cars, before the refueling ban.
that´s what they officially give away...saw the press kit todays.
Gridlock
42
Sure that's not already wheelbase?
#58
I´ll double check ..
Med4224
Few are those who see with their own eyes and feel with their own hearts.
Albert Einstein
FrukostScones
Med4224 wrote:no total length is 4800
http://www.motorsport-total.com/f1/news ... 22104.html
doesn't matter what they say it is aprox: 5000mm long , wheelbase is 34XXmm.
Measured with ruler.
Measured again, again with ruler: 5200mm long, Wheelbase 3520mm
"I ain't with the FIFA, I'm in Tokyo." LH
Gridlock
42
An F1 team not being truthful? Never!
#58
which photo did you use?
snoop1050
snoop1050
just find out how tall one of the drivers is and find a pic of them standing next to the car with the photo taken at a side angle if you want to calculate the length with any accuracy
MIKEY_!
I'd use the distance from the front of the FW to the back of the front wheel.
DAMNINice
37
Why isn`t Mercedes using a big starter hole as RB on the RB8??
That would help alot on their mini DDD!?!
REal men play with twins!
Med4224
I measured it again, assuming wheel+tyre diameter is the maximum of 660 mm
Total length: 5050 mm +/- 15
Wheelbase: 3515 mm +/- 15
So i guess the consensus is that the wheelbase is around 3510 - 3520
Albert Einstein
