Scuderia Ferrari SF71H
Re: Scuderia Ferrari SF71H
That'd be a nightmare in terms of ergonomics when glancing at vibrating mirrors at 180mph.
The great big chipped vertical line up the middle is what he's refering to, where it's broken.
DiogoBrand
74
SectorOne wrote:
04 May 2018, 17:58
That dark edge chip is a reflection of the carbon housing.
1. Notice the white line.
2. Notice the edge of the carbon housing.
https://i.imgur.com/c0jtSrq.jpg
My guess is the innermost mirror is set up normally, showing whats to the left and right of the rear wing.
The outer part shows what´s between the rear wing, right behind you.
edit: now it might be a broken mirror but it´s a clean crack.
But that must mean that edge is also another separate piece, because it wouldn't make sense for just that triangle to reflect the mirror housing, and if that's the case, I think it would be way more likely for the mirror to be broken than Ferrari dividing it in three intentionally.
Big Tea
99
SectorOne wrote:
04 May 2018, 16:48
Big Tea wrote:
02 May 2018, 18:38
My car has mirrors like that. One gives a view wider out, one closet to me. I find it useful when pulling out to overtake on a 3 lane as I see the outside sooner if there is traffic in the middle lane, but not too close. Also useful on roundabouts.
But these will do the exact opposite since this is concave, not convex which allows you to see your deadzone.
Im guessing these are for a clearer view on whats right behind him.
My mirrors are not curved at all, just flat but at different angles.
Inner 2/3ds is a standard rear view outer 1/3rd is exactly as if the same mirror was adjusted outwards
SectorOne
DiogoBrand wrote:
04 May 2018, 21:47
I think we are over complicating things here now.
There´s two mirrors in the housing, one of which has a sharper angle then the other one.
If its intentional or not we can´t say but the number of them we can safely say is two.
DiogoBrand
74
SectorOne wrote:
05 May 2018, 09:57
DiogoBrand wrote:
04 May 2018, 21:47
I see it now. I was thinking the outer part was reflecting the rear wing, with that tiny triangle reflecting the mirror housing, which would make no sense if the mirror wasn't broken, but now I do realize the outer part is actually reflecting the head support while the small edge reflects the housing. Makes a lot more sense, makes it more plausible that the concave shape for the mirror is intentional, but still I see no good reason for Ferrari using a concave mirror. Let's wait and see if that mirror is still there for Spain.
paddyf1 wrote:
03 May 2018, 10:45
"It seems that this hollow fairing of the mirror does not serve to direct the airflow towards the upper sidepod inlet, contrary to what was thought at first.
Put simple, its role would rather be to improve the airflow towards the rear wing and diffuser. Its shape would certainly create a little more drag, but it would also generate a wake of higher pressure, more energized than with a conventional design, which helps the elements further down (the rear wing and the diffuser) in generating downforce".
Could you please post links of those articles you are quoting? I've found it on F1i.com. They've probably read Steven's article, posted more than a month ago:
https://www.f1technical.net/development ... eally-work
JoeSmith
JoeSmith
Vanja #66 wrote:
05 May 2018, 16:25
paddyf1 wrote:
03 May 2018, 10:45
I wonder why they put it in the mirror ?. IMHO, halo device have larger surface to do that
Most teams do it with Halo fairings, yes.
paddyf1
paddyf1
Boston-George
Boston-George
It added three tabs to the upper surface/corner of the mirror, shielding the strakes if the car were to be viewed from above.
Why is it not allowed to see the strakes from above?
JRodrigues
JRodrigues
16
Two mirrors:
djos
115
Fascinating, I'd have thought a single panoramic mirror would have been a better choice from a driver's vision pov.
"In downforce we trust"
JRodrigues
JRodrigues
16
Don't know if that is just a 'Kimi thing'... Vettel seems to have just one mirror:
Zynerji
112
JRodrigues wrote:
08 May 2018, 13:01
https://cdn-9.motorsport.com/images/mgl ... -sf71h.jpg
https://cdn-9.motorsport.com/images/mgl ... detail.jpg
Maybe it's an age and eyesight thing!!
:lol:
ema00
ema00
it seems broken
