Red Bull RB10 Renault
SiLo
144
Re: Red Bull RB10 Renault
Haha, I was going to saw what are you on about?
There are clearly three small slots sitting right behind the main plane of the wind there, a strange place to put them but I'm guessing they are helping to disperse some pressure from below the wing by exhausting it through the endplate as well as from under it.
Felipe Baby!
bhall
bhall
244
IF the end plates do have slots behind the wing, which is a more interesting conversation at this point anyway, my guess is that they're somehow linked to DRS.
Red Bull hasn't run traditional end plate slots over the wing at all this year, presumably because the slot gap between the main plane and the flap appears to be set at, or near, the maximum 15mm allowed by 3.10.1. A slot-gap that large isn't likely to cause a massive need to relieve pressure in order to reduce vorticity from the wing tips. But, that lack of slots could change the way the wing "stalls" when DRS is activated, or even how air flow reattaches once DRS is disengaged. You want both of those things to happen as quickly and orderly as possible.
Enter the new slots? I dunno.
Absent that, I can't think of a reason why you'd want to increase pressure behind the wing. Teams tend to spend a lot of time and money to reduce pressure in that area as much as possible, because that local lack of pressure is called downforce.
Gaz.
Gaz.
Blackout wrote:I thought the RB10 is using an air-water intercooler when I saw thos pics (because it lies very far from the sidepod air duct. But it seems the RBR has two intercoolers like the other Renault cars... so maybe it's just an air-air intercooler...
http://www.servimg.com/image_preview.ph ... u=14795526
Are they not twin air-water chargecoolers?
Forza Jules
user001
user001
-2
ringo wrote:
Juzh wrote:
prince wrote: When the car runs at full power of 15k RPM and achieves peak torque, for a long duration is when we know if the problems of overheating are conquered or not. For now, there are problems of varying degree and various nature are present.
Max power is not at 15k rpm and no one will run 15k rpm unless 8th gear where they'll need those revs. Just saying..
I think 15000 rpm will be used in some turns, especially the longer lasting ones.
Earlier this year it has been mentioned by Cowell that the engines will NOT go far north than 11000 rpm cause of fuel consumption <-> fuel effiency
user001
user001
-2
atanatizante wrote:http://imgur.com/c8v97IY.jpg
From the first time I saw the rear of the RB10 (and E22), I asked myself at which temperature and speed does the hot air exit the bodywork?
-> heat blown diffusor?
Chuckjr
Brilliant question Sector One.
Maybe Newey has realized the same complexity as nature did with sun spots...they should reveal the core of the sun and therefore should be the brightest/hottest part of the surface yet they are the coldest and darkest part. Maybe the same physics factors are at work here. :)
Just a bit of humor...moving along people... :D
Watching F1 since 1986.
Yurasyk
Yurasyk
I think I've cracked genious Newey plan to hide front camera pods inside nosecone in order to make impossible filming of suspicious splitter and stay movements by a looking backward TV camera. :D
Robbobnob
Robbobnob
Slower than the free stream air on the exterior of the car. In fact Redbull use the high velocity air and hence subsequently low pressure air to draw the air out of the body work to increase the effectiveness of the cooling
shelly
shelly
136
I am not sure how much cooling outlet's air is slower than outside air. Continuity equation holds - so it has more or less the same speed as inlet air - bar inlet-outlet section ratio.
How muche slower the speed at the inlet of the raidtor is?
twitter: @armchair_aero
2014 Australian Grand Prix - Saturday, 15.03.2014
NathanOlder
Hi guys, can someone tell what this is circled in yellow please. There is one the same on the other side but it looks green inside as opposed to red like this one.
GoLandoGo
Lewis v2.0
King George has arrived.
bhall
bhall
244
NathanOlder wrote:Hi guys, can someone tell what this is circled in yellow please. There is one the same on the other side but it looks green inside as opposed to red like this one.]
Torsion bar (spring)
NathanOlder
Ah, Thanks :)
GoLandoGo
Lewis v2.0
jagunx51
185
just a camera angle ....or is it an extreme rake/set up that the floor almost touch the tire ?
different rear wing mid-pillar .......the color of the exhaust pipe, different by coating material or just a sunlight reflection ??
That picture was damn confusing; it looked like the pillar was actually resting on the exhaust, but optical illusion messed up the view between the pillar and the RW endplate on the background.
