![Image](http://images.f1racing.net/large/38898.jpg)
![Image](http://images.f1racing.net/large/38903.jpg)
Old 2 exhaustsAnonymous wrote:It has 2 exhausts... the picture is just taken at a misleading angle
Yeah, you're right. That picture I quoted does look quite convincing though.Anonymous wrote:Old 2 exhaustsAnonymous wrote:It has 2 exhausts... the picture is just taken at a misleading angle
http://images.f1racing.net/large/38909.jpg
New 1 exhaust
http://images.f1racing.net/large/38904.jpg
It still is a twin keeler. As you indicate, the pick-up points are higher. I believe this is why the strut we used to see between the two keels are now absent (improved stiffness).Ciwai wrote:Not conclusive but it still appears to be a twin keeler. Geometry seems more like last years williams with the angled upper arms. Higher pushrod mounting points necesitate dimples on the nose. Nose shape looks similar to the wide nose that was tested last year. I'm surprised how similar the front wing is to last years car.
From the sidepods back looks really clean--chimneys really look to be a tidier solution than the winglets/outlets on the B. Overall roundedness as sidepods taper back is even more reminiscent of R24. Airbox is terminated in a straight cut at the back. Subtle changes to paint graphics--red swoosh extending around nose/grey chimney section are nice.
