Mercedes AMG F1 W03
THENOMAD79
THENOMAD79
-5
Re: Mercedes AMG F1 W03
DON T WORRY ABOUT THIS HEATING, ALL THINGS IS BE FINE SOON :idea:
razno
razno
THENOMAD79 wrote:DON T WORRY ABOUT THIS HEATING, ALL THINGS IS BE FINE SOON :idea:
With a little bit of gills here, and then there... :twisted:
Intego
Lurk wrote:
atanatizante wrote: I know that RW F-duct is forbidden but if it`s a passive one then it`s allowed?
Forbidden too. The main & secondary flap of the rear wing must have a closed section. So it doesn't allow a slit to run an F-Duct.
But you could run a passive one on the front wing and on the beam wing.
IIRC the passive solution on the rear wing is not forbidden but the teams agreed not to use it. Dunno whether this is for the beam wing also.
"Posts targeted only at expressing favouritism or dislike towards people are treated as spam. They can hence be deleted without notice and could invoke a warning to the poster." f1technical forum rules
silvertouringz
silvertouringz
aduka11 wrote:Im very worried about Merc cooling issues...
Any news about it?
From the pictures i saw, things don't look good...
[img]http://img804.imageshack.us/img804/8541 ... 2s.jpg[img]
some header wrap will do the job :lol:
Reason: Removed quoted image from post above
dontempe
dontempe
dren
226
"enhanced"
Honda!
cirrusflyer
Any info about sector speed and top speed in comparation to other cars?
If flying were the language of man, soaring would be its poetry.
It's all about technology!
When you go fast, do not hesitate to go faster!
Lurk
It won't mean anything. We won't know who was using DRS, if there was someone ahead or not and if they run a low DF setup or not...
Yes it is. FIA added the word "closed" into the 2011 regulation article concerning rear wing flaps (3.10.2) to avoid passive F-Duct system.
When viewed from the side of the car, no longitudinal vertical [2012] cross section may have more than two sections in this area, each of which must be closed[2011]
more enhanced pics
On the first & second one, there is clearly a twin slot inside the sidepod entry. This car has a lot of small inlets everywhere - even if these two are not that small.
There is also a 'tunnel' (sorry, don't know the word... I hope it would be clear) on the turning vanes under front bulkhead (don't know the word either :lol: )
On the third pic, it seems that the vertical fin behind the rear wheel is burned too.
Front splitter looks complicated but it could be just the view angle...
Beam wing is higher than I tought.
bar555
bar555
Mercedes W02 had also overheating issues at first tests . W03 sidepods feature detachable patches offering multiple cooling options, some of which will be tested for sure at Barcelona .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Owen.C93
Owen.C93
171
Front wing hole: Image
Right click-View
Ferraripilot
21
What's that gap under the brake light and the diffuser? Are they blowing something between there like Ferrari may be doing?
dren
226
No rear wing slats below the wing. Just two turning vanes in the diffuser on each side. No slotted gurney on the diffuser. It looks pretty ordinary. Has anyone seen the starter hole yet?
Honda!
dren
226
Ferraripilot wrote:What's that gap under the brake light and the diffuser? Are they blowing something between there like Ferrari may be doing?
I noticed that too, not sure if it's just the larger gurney that connects to the crash structure or not. Almost looks like the diffuser extends up in that area.
Honda!
Ferraripilot
21
there is definitely something going on here
Leon
Leon
16
Welcome W03. Wish you all the best. Be fastest, most reliable and win as much as possible.
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
