So these would be the slots for the FW F-duct then?
I said something similar earlier...Diesel wrote:Those slots on the bottom of the front wing are the conclusive proof of the front wing f-duct. Clear to see the ducting from the rear wing is heading forwards. My guess is it's simply being used as a switching device, so the velocity of the air travelling through it isn't too important, it's more about the pressure. For it to work though, the air that is coming in through the nose hole must be exiting somewhere other than the wing slots when the f-duct is in the off position. I guess it could be just exiting in to the cockpit?
I think what you describe is not possible, or at least not allowed.aduka11 wrote:I said something similar earlier...Diesel wrote:Those slots on the bottom of the front wing are the conclusive proof of the front wing f-duct. Clear to see the ducting from the rear wing is heading forwards. My guess is it's simply being used as a switching device, so the velocity of the air travelling through it isn't too important, it's more about the pressure. For it to work though, the air that is coming in through the nose hole must be exiting somewhere other than the wing slots when the f-duct is in the off position. I guess it could be just exiting in to the cockpit?
Its too complicated for air to travel trough whole car...
Rear wing duct has some sort of switch or sensor...which gives signal to vent in front of the nose to switch from directing air from driver cooling to Front wing...
Far more simple...than making one long tube trough whole car...
I think the switch he had in mind was a fluidic switch.Tomba wrote:I think what you describe is not possible, or at least not allowed.aduka11 wrote:I said something similar earlier...Diesel wrote:Those slots on the bottom of the front wing are the conclusive proof of the front wing f-duct. Clear to see the ducting from the rear wing is heading forwards. My guess is it's simply being used as a switching device, so the velocity of the air travelling through it isn't too important, it's more about the pressure. For it to work though, the air that is coming in through the nose hole must be exiting somewhere other than the wing slots when the f-duct is in the off position. I guess it could be just exiting in to the cockpit?
A switch like this would mean moveable aerodynamics, at least under the FIA naming, hence would be outlawed.
Charlie Whiting also said yesterday that "some teams" are using a ducting system with the rear wing "which includes no moving parts". With my understanding that the DRS switch can only be used to upper or lower the rear wing flap, I see no legal possibility to use that DRS switch signal for anything else.
Yes it was, the same f-duct concept McLaren came up with, just its reversed.beelsebob wrote:I think the switch he had in mind was a fluidic switch.Tomba wrote:I think what you describe is not possible, or at least not allowed.aduka11 wrote:
Somewhere in this topic there's a picture of a small intake on the leading edge of the same winglet you see the slot in from the bottom.MIKEY_! wrote:They could have an intake on the wing but I'm yet to see one there.
