This is NOT true in all cases. I can bond a flat surface to my two concave surfaces, ) ( .PhillipM wrote:Every manufacturable point does, yes.
3.10... When viewed from the side of the car, no longitudinal vertical cross section may haveTatsu333 wrote:This would then also rule out any type of opening in the rear wing planes outside of the central 15 cm of width. A hole of any size or shape, never mind a slot, would expose the internal surfaces of the wing to the external airstream if you interpreted the rule that way.
That would be ideal but....QLDriver wrote:If this stalls with the DRS, then wouldn't that actually balance the car better at high speed?
1. didnt the teams achieve the exact same but opposite effect in 2010? from top of the nose to rear wing?? why cant it be do the opposite....it could be a fluidic switch where air flows from the tip of nose through to the endplate hole where it bleeds out when DRS is openhardingfv32 wrote:That would be ideal but....QLDriver wrote:If this stalls with the DRS, then wouldn't that actually balance the car better at high speed?
1) You have to get the DRS 'flow' signal to the nose. Getting a useful flow from the small DRS holes to the nose is virtually impossible.
2) We do not have a source for the primary flow for the front wing.
3) We have not seen any slots on the front wing for the primary flow to exit from.
Brian
The fluid switch would have been located on the air box, a much shorter and less contorted route than what is now being proposed. This is an almost impossible pneumatic objective.siskue2005 wrote:1. didnt the teams achieve the exact same but opposite effect in 2010? from top of the nose to rear wing?? why cant it be do the opposite....it could be a fluidic switch where air flows from the tip of nose through to the endplate hole where it bleeds out when DRS is open
Too small. Also the air flow must make at least three 90 deg bends losing 60% of its flow velocity along the way.2. From the nose hole!
siskue2005 wrote:1. didnt the teams achieve the exact same but opposite effect in 2010? from top of the nose to rear wing?? why cant it be do the opposite....it could be a fluidic switch where air flows from the tip of nose through to the endplate hole where it bleeds out when DRS is openhardingfv32 wrote:That would be ideal but....QLDriver wrote:If this stalls with the DRS, then wouldn't that actually balance the car better at high speed?
Brian
3. you can see some sort of slot in the front wing, we need better pictures
