Blaze1 wrote:Yesterday Lewis ran with the FDRS installed, which is designed to stall the centre of the rear wing. Would it be possible to have a similar device fitted to the rear wing end-plates, that blows inwards out of holes/slots on the inside of the end-plates to stall the outer portions of the rear wing?
Perhaps the regs prohibit 'holes' in the rear end plate body work region?
The outside is almost impossible to stall. The flow is very attached on the back of the wing and end plate there. Also the upwash is greatest on the outer edge.
It would take tremendous amounts of momentum energy.
It's easier to stall the weakest flow on the wing, which happens to be in the middle. This flow is the weakest and most sensitive.
