Ferrari F14T
Re: Ferrari 2014 Car Pre-launch Speculation
Apart from MCD's doesn't look like a duck-billed platypus that's wandered under a blow lamp :lol:
Huntresa
Huntresa
Also double support for RW.
Holm86
247
Those are the smallest sidepod intakes yet!!!
FrukostScones
162
no Penis but so ugly! worse that 2012! only Lotus tops it atm.
Hail22
144
darkmninya wrote:Pull or push rid
Chassis
Chassis in carbon-fibre and honeycomb composite structure
Ferrari longitudinal gearbox
Servo controlled hydraulic limited-slip differential
Semiautomatic sequential and electronically controlled gearbox with quick shift
Number of gears 8 +Reverse
Brembo ventilated carbon-fibre disc brakes (front and rear) and brake by wire rear brakes
Independent suspension, pull-rod activated torsion springs front and rear
Weight with water, lubricant and driver 691 kg
OZ Wheels (front and rear) 13”
http://f14t.ferrari.com/en/#techspecs
Gilles Villeneuve
FrukostScones
162
Holm86 wrote:Those are the smallest sidepod intakes yet!!!
Lotus' look smaller.
gary123
stefan_ wrote:Spazzaneve v2.0
LOL! :lol: :lol: =D>
Unc1e_M0nty
Back end looks fantastic, that nose is pretty ugly though, the bulkhead looks way too high as well, I need to see it along side the Macca & Lotus.
Pilatus
22
It looks like a vacuum cleaner.
f1rules
f1rules
597
i dont understand, that high chassis and then the air blocked with that front, quess thats why im no engineer
Crabbia
Crabbia
Pull rod front retained. I'm not overly surprised or upset.
Never thought that someone would try that nose, let alone ferrari.
A wise man once told me you cant polish a turd...
geraldix
geraldix
Sidepods air intakes are VERY tiny compared to what we've seen so far, and the sidepods themselves also look very slim.
Holm86
247
Bit surprised they've retained pull-rod front.
Rikhart
Rikhart
19
Oh god that thing is HORRENDOUS. Ferrari ugliest car 2014?
AnthonyG
38
Funny car, it makes me smile for some reason.
