Team: Pat Symonds (CTO), Jason Somerville (CA), Ed Wood (CD), Dickie Stanford (TM), Rod Nelson (CTE), Frank Williams (TP), Claire Williams (DTP) Drivers: Felipe Massa (19), Valtteri Bottas (77), Felipe Nasr (Reserve), Susie Wolff (Development Driver) Team name: Williams Martini Racing
Massa is a pretty light driver and he can put the things pretty difficult to Bottas.
The design of this car is quite clear but nothing innovative regarding the 2012/2013 I think I'm seeing dejavu every year at the rear in this car.
williams is able to pack things so tight with their innovative gearbox [which they've been running for some time now],
but i'm getting the idea they're not benefitting that much from it. the exhaust is like a cannon popping out there.
i wonder whether that gives them negative aero. on the other side, it may reduce a small amount of heat buildup
within the engine cover. apart from that, the 'smaller' packaging will help them gain a lower COG.
the car looks remarkably well packaged and i can't remember being enthusiastic with williams since the early to mid nineties.
mercedes being the engine supplier could give them a very good boost in performance. Still, it's far too early to tell, and sometimes i wonder whether there's something wrong at the entire williams team that blocks them performing.
Remembering they had a gp-winning car 2 years ago - and i suspect that if there had a A-class driver in there they'd won
more and went on podium a tad more frequent - it's odd how they dropped so extremely far back last year. Then they tested
without the coanda effect and they actually gained some performance. It gives me the impression that there there is a certain amount of people around that aren't capable enough to process the data in a way that williams can get a positive development.
That doesn't make the people over there useless or bad - but as with most things, negative results usually originate from bad communications and not enough 'cooperation'.
I just hope to see Williams jumping back to the front. I've lost hopes with them for years, and i've been thinking they're going to fade away and become another team in due time - but i've got my hopes high with this one. MAybe the new f1 format will aid them. If not.....well, then i think the nail has come to the coffin.
Manoah2u wrote:williams is able to pack things so tight with their innovative gearbox [which they've been running for some time now],
Everyone 2 years ago almost had a GP winning cars with how those tyres worked. Williams wouldnt have been close to winning without the tyres in 2012. But that doesnt take away from this car, which looks rly good and hopefully it will revive Massa from his Ferrari stasis...
The Williams FW36 Simulates Double Diffuser? The Williams FW36 has the two central pillars that hold up the rear wing: Grove of the car, then, as a support, using two-storey wing which are mounted just above the rear diffuser, the sides of the crash box. The function is twofold: to fasten the side walls (since the only profile extractor would not be able to handle the load) and try to reproduce the effects of the "beam-wing" that year was banned by regulation.
The feeling is that the aerodynamic Williams seek to realize a sort of double diffuser in a very sensitive area of the car because invested by the hot air which is extracted from the sides ...
