Multi-valve technology
auteoch
auteoch
J.A.W.
J.A.W.
109
Re: Multi-valve technology
What a lovely wee row of poppets..
ojlopez
ojlopez
You should remove that picture, it might be considered porn and have this site shut down :D
J.A.W.
J.A.W.
109
Or here's an idea to market as "F1 Art"..
Coat the head gasket face with paint, put more paint in the ports, lay it while wet on a canvas ( or fresco, paper & etc),
then give the valves a sharp tap with a hammer, & remove.. ..to reveal the flow pattern spray in all its glory..
Remember guys - you read it here first, (for intellectual property royalty purposes).. ..L.O.L...
riff_raff
riff_raff
Do you have a picture of the cams used with that cylinder head?
A: Start with a large one!"
568
No - but there are five of them with direct acting buckets. :D
J.A.W.
J.A.W.
109
riff_raff wrote:Do you have a picture of the cams used with that cylinder head?
Seriously r-r..
..you surely cannot..
.. actually believe..
..that..
..such an image..
..has any material reality..
..outside of a photo-shop ?
Ciro Pabón
106
Ciro
J.A.W.
J.A.W.
109
Not.. quite.. my concept C-B,( but still artistic for sure) ..so.. ..you might've got away with that one.. ..L.O.L...
riff_raff
riff_raff
J.A.W. wrote: Seriously r-r..
..that..
..such an image..
Yes J.A.W., I grasped the fact that the cylinder head image was Photoshop'd. And I hope you grasped that my question about the camshaft was also asked in jest.
Frankly, I was hoping some clever person would put together a composite image of a twisted/convoluted/forked camshaft that somehow mated up with all four of the different valve arrangements.
Cheers.
J.A.W.
J.A.W.
109
Yeah, right.. r-r, of course you were..
Actually, I'd reckon Honda might take on that task as one of their wacky engineering competitions..
( 8 valve oval piston anyone?)
& having worked on a few of their wacky production rocker set-ups, I reckon it'd be right up their alley too..
471
riff_raff wrote:Frankly, I was hoping some clever person would put together a composite image of a twisted/convoluted/forked camshaft that somehow mated up with all four of the different valve arrangements.
Dual underhead cams with pushrods. One either side of the block.
J.A.W.
J.A.W.
109
Just like an old Riley, or Triumph Speedtwin..
Although Honda have made a few pushrod mills too, including their then super-tech turbo CX 500, back in the `80s..
I ran a competition SOHC 4-valve per cyl Yoshimura-cammed Honda that habitually broke rockers under the strain..
riff_raff
riff_raff
Whoever created that photoshop image actually put a bit of thought into it. All of the intake and exhaust valves are located on the correct side of the cylinders.
J.A.W.
J.A.W.
109
Fairly bloody self evident, really, r-r, aint it?
Not that every deep breathing poppet valve head has to be - per se - cross-flow..
See.. http://www.chiheads.com.au/shop/hemi-cy ... nder-head/
