Also the old Formula1 website map:
Tire choices:
Soft (Option)
Medium (Prime)
2014 Results:
2014 Pole position lap:
At almost all circuits, before the DRS straight starts, there is always downforce dominated curves that comes and that is where the car with higher downforce escapes from a car with top speed (presumably low downforce setup). At Shanghai, the sector 2 is high downforce sector with a great long right hander that comes before the long (longest in F1) DRS back straight comes. If the leading car gets about 8 tenths at the start of that straight, it is difficult for the chasing car to make an overtake. It actually makes sense for Nico to run same amount of downforce as Lewis, because then, he can be right behind when the straight starts and can then make use of DRS, if he is behind lewis.CBeck113 wrote:I think Hamilton will go for pole, which means their normal DF levels, but if I were Rosberg I'd go for more top speed to have a chance to pass him. But the chances of that happening are slim to none; he'll just say that he drove poorly and Lewis beat him.
SectorOne wrote:Will be interesting to see how much closer (or further back) Ferrari is here with more normal temps.
15 degrees C. can hardly be qualified as normal temperature for a race week end. Looks like we''ll have to wait until Bahrain with average temperatures of 25 degrees C. or maybe even Spain, where the temperatures will be constant through out the race.As per the current weather prediction, it would be raining until mid of next week and possible showers on satuday with cloudy sunday and temperatures around 15 deg C.
How much is tyre grip a factor in high downforce corners? IMO - when the tyre starts to go, it doesn't matter if you're in a high downforce corner or a low, mechanical one - the lowest common denominator will probably be the tyre? The reason why I am raising this point, is if Nico really has some kind of edge on tyre wear (as he possibly had in Malaysia), he may find himself with better grip at some point towards the end of a stint. The question then becomes if he will have an advantage with a lower downforce setting to gain a bigger speed differential within the DRS zone or if a more identical setting might prove better.GPR-A wrote:At almost all circuits, before the DRS straight starts, there is always downforce dominated curves that comes and that is where the car with higher downforce escapes from a car with top speed (presumably low downforce setup). At Shanghai, the sector 2 is high downforce sector with a great long right hander that comes before the long (longest in F1) DRS back straight comes. If the leading car gets about 8 tenths at the start of that straight, it is difficult for the chasing car to make an overtake. It actually makes sense for Nico to run same amount of downforce as Lewis, because then, he can be right behind when the straight starts and can then make use of DRS, if he is behind lewis.
Here we go again... [-o< There should be a rule here that forces to back up claims like that. I'm guessing this "seems" is based on two races and ignores two full seasons of something opposite? Fine, quick question: with all conditions clearly not being the same who do you think was faster in Malaysia race? However irrelevant to finishing position it was but since we're discussing predictions with vague "beating" and "conditions" looks like Rosberg didn't have to wait long for a chance. Anyway, for China:CBeck113 wrote:You basically said what I was thinnking about Lewis - under the same conditions Nico can't seem to beat him, so he needs to start going other ways to at least try it. Waiting for Lewis to drive worse than himself ... naaa, won't win him a title, that's for sure.
A lot of that was down to the heat. It's not normal for you to be able to cook an egg on the floor of an F1 track.Juzh wrote:It seemed to me mercedes wasn't particularly good in slow off camber corners in malaysia, 2nd to last corner especially, whereas ferrari was just pure awesome. It will be interesting to see whether or not this will be of some benefit to ferrari in China or if it was purely down to tires.
