I'm pretty sure they're developing everything they can, if not everything with the same level of financial commitment. They never know when the FIA will open the token system up a little more to help the struggling engine firms catch up.Blaze1 wrote:They certainly don't develop all aspects of the engine, as some of these e.g the block are already frozen. I think they analyse what areas can be improved upon within the token system and then work on those areas. This may lead to multiple paths of development for a specific system (e.g turbo designs), so it is expensive. At the end of the development cycle (if it hasn't been realised before this point) they'll select the most suitable design.
Developing everything would be a waste of resources. Also the PU works together as a package, so a specific system designed as part of a complete PU overhaul, may not work efficiently when fitted to frozen part of the package.3jawchuck wrote:I'm pretty sure they're developing everything they can, if not everything with the same level of financial commitment. They never know when the FIA will open the token system up a little more to help the struggling engine firms catch up.Blaze1 wrote:They certainly don't develop all aspects of the engine, as some of these e.g the block are already frozen. I think they analyse what areas can be improved upon within the token system and then work on those areas. This may lead to multiple paths of development for a specific system (e.g turbo designs), so it is expensive. At the end of the development cycle (if it hasn't been realised before this point) they'll select the most suitable design.
