Link doesn't work for me.
Equating downforce to weight is fairly simple though - the equation for lift is
and obviously the weight is given by
. Downforce for an F1 car
will exceed it's weight, so all you're working out at which speed it does. So
, at that speed the car will be neutrally buoyant so anything faster than that the car will be producing more in downforce (if upside down that's lift) than the weight pulling it down.
-5 to -5.5 for a current grand prix car, and mass (dry) is 734kg this year. International standard atmosphere figure for
at 15
at sea level is 1.225
As the wing must fit within a box defined by the regulations the size of a wing isn't proportional to its force, the camber and incidence, are more important. e.g. monaco and monza wings have the same planform area, but the monaco wing will produce high downforce and high drag, while the monza wing is the opposite.
