Cooling fans on F1 cars
Big Tea
99
Not sure if this should be here of in general?
I was wondering now that the MGU-H can supply power the car can not legally use if it was at all feasible or even of any advantage to use it to power electric cooling fans.
Not only for on the grid and safety car, but we often hear of cars 'staying in the clear air' when they have been following for a while.
roon
roon
412
Re: Cooling fans on F1 cars
Fans likely considered as bodywork. Moving bodywork prohibited. There may be an explicit mention of fans in the cooling system section of the regs. Regardless, one would have to compare the mass and location of any fan and its ductwork, and whether they would provide any improvement over ductwork which can supply air from a ~60-300kph variable source.
Big Tea
99
I can not see a specific reference unless it is covered by 3.8 Aerodynamic influence
I suppose though the weight and position would be more beneficial as ballast where needed.
roon
roon
412
Should be the same rules that rendered Murray's fan car illegal.
strad
117
I'd bet that it would be illegal but I don't see how it is a moveable aerodynamic device.
Sir Stirling Moss
AJI
AJI
27
Big Tea wrote:
30 May 2018, 22:32
Are you talking radiator fans? They'd only be useful on the grid after the formation lap, so, for about 15 seconds per race for the guys on the front row. I'm pretty sure they have them. They used to anyway… Well, the RB7 did at at least one race..
roon
roon
412
AJI wrote:
31 May 2018, 01:02
Big Tea wrote:
30 May 2018, 22:32
http://f1grandprix.motorionline.com/wp- ... ll-RB6.jpg
That's a pre-2009 demonstration car for press events. Note the pushrod rear suspension, low rear wing, and crash-structure-diffuser.
AJI
AJI
27
roon wrote:
31 May 2018, 06:29
Well that explains it. I thought it looked particularly un-F1.
Cold Fussion
Cold Fussion
93
Even if they were to use fans, I highly doubt it would be slapped onto the back of the radiator without any form of ductwork.
