F1 V10 Intake Camshaft Spec, a closer look
Brian.G
Brian.G
334
Another part under the spot light, this time the V10 Intake Camshaft.
In this thread I will be unlocking a few secrets hidden within this part - the F1 V10 Intake Camshaft, mainly its features in terms of design, drive and oiling, and most importantly the lift numbers. It's from my own Cosworth F1 V10 TJ engine. This Engine was from the last of the V10's during 2005 and an important one since it is N/A, and has a high Redline - @ 19,000rpm.
As some of you may know - the camshaft was driven with a quill shaft - this shaft acted as a torsion bar and in turn lessened fluctuations in angular velocity.
The DLC coated intake cam as well as the drive quill can be seen below.
A close up of the quill splines as well as the hollow cam bore below that,
The valve actuation is via finger followers as shown below,
These bolt into pockets along the I-beam head,
They are cooled with a jet(removed) that is screwed into a drilling above the follower pivot,
A shot of the cam and finger follower, as well as the mock valve stem used to take the lift measurements,
A cutaway of the TJ engine showing general layout,
The rig setup shown below used to take lift measurements,
A MAHR wireless calipers was used to create the lift vs angle chart. The calipers has the nice feature of being wireless and can populate an excel sheet on command - which saves a lot of writing and possible errors.
A 360 degree wheel was fixed to the end of the cam. The cam was then rotated to the points where it just started to lift the valve off seat(.01) and also to the point at which the valve came back on seat(0.00). The angular distance between these two points was then halved and this was the position TDC was assumed on the degree wheel. Please note, this may not be the actual TDC point of the engine but it did seem a good place to start taking measurements and in reality a better term would be lobe center line since max lift was seen at 180 degrees.
Some key measurements were noted -
Intake valve starts to open at 63 degrees after TDC (''off seat'' on degree wheel - wheel turns clockwise)
Intake valve comes back on seat at 298 degrees after TDC (''on seat'' on degree wheel - wheel turns clockwise)
Max lift - 15.95mm @180 Degrees after TDC.
The plotted graph -
The lift dimensions are listed below for ease of copy and paste should anyone want to analyze the numbers in more detail - Vel, Acc, etc.
Please beware they are to be placed beside a cam angle list from 1-360 degrees.
0.02
0.03
0.04
0.05
0.06
0.08
0.09
0.1
0.11
0.12
0.14
0.15
0.16
0.17
0.19
0.2
0.21
0.22
0.23
0.24
0.25
0.27
0.28
0.29
0.3
0.31
0.33
0.34
0.35
0.36
0.38
0.39
0.41
0.43
0.45
0.47
0.5
0.53
0.56
0.59
0.64
0.68
0.73
0.79
0.85
0.91
0.98
1.05
1.14
1.26
1.35
1.45
1.58
1.7
1.87
2.02
2.2
2.36
2.58
2.79
3.02
3.25
3.5
3.76
4.02
4.34
4.58
4.91
5.2
5.52
5.85
6.11
6.49
6.79
7.13
7.46
7.78
8.13
8.45
8.79
9.13
9.44
9.78
10.08
10.39
10.7
11.59
11.86
12.15
12.4
12.67
12.9
13.15
13.37
13.6
13.82
14.03
14.23
14.42
14.59
14.77
14.92
15.08
15.21
15.33
15.44
15.55
15.65
15.73
15.79
15.84
15.89
15.92
15.94
15.95
15.95
15.95
15.95
15.92
15.87
15.8
15.73
15.63
15.55
15.44
15.32
15.18
15.04
14.89
14.73
14.54
14.35
14.15
13.96
13.77
13.55
13.3
13.06
12.8
12.58
12.28
12.04
11.75
11.48
11.2
10.89
10.6
10.29
9.99
9.64
9.33
8.99
8.65
8.32
8.03
7.68
7.34
6.99
6.63
6.3
5.99
5.58
5.28
4.94
4.62
4.28
3.97
3.64
3.33
3.05
2.75
2.5
2.25
1.59
1.4
1.24
1.11
0.98
0.86
0.78
0.7
0.64
0.59
0.55
0.51
0.49
0.46
0.44
0.43
0.42
0.41
0.4
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.3
0.29
0.28
0.27
0.26
0.25
0.24
0.23
0.22
0.21
0.2
0.19
0.18
0.17
0.16
0.15
0.14
0.13
0.12
0.11
0.1
0.09
0.08
0.07
0.06
0.05
0.04
0.03
0.02
0.01
Thats all for now - Enjoy,
Brian,
If you think you cant, you wont, If you think you can, you will
daniellammers
daniellammers
Re: F1 V10 Intake Camshaft Spec, a closer look
Those numbers are awesome. But I've got a few questions:
- How did you figure them? Just measure it?
- Do you own the engine?
- What material is the camshaft?
You won't catch me driving a race car that I have built.
- Colin Chapman
Brian.G
Brian.G
334
daniellammers wrote: ↑
25 Jun 2018, 22:01
Yes - as pointed out above with a Mahr Digital wireless calipers + degree wheel. 360 measurement points in total.
Yes
Steel'.
Brian,
e36jon
e36jon
66
Thanks for the continued generosity with all the details Brian! It's really amazing to see the parts and your analysis just makes it that much better.
Jon
Always look forward to your threads.
The layout of the head is certainly interesting. I was looking forward to see both cams in place in this weird "wall mounted" layout. Would be great if you could post that.
For the lift profile. It seems the valve opening ramp is gentler than the closing ramp.
Nearly 16mm of lift is pretty aggressive.
The opening angle of 230 degrees is also very aggressive too.
BrunoH
BrunoH
great stuff!!
Brian.G
Brian.G
334
PlatinumZealot wrote: ↑
25 Jun 2018, 23:47
Here is an image if the v10 head in question - It was called the I-beam design and gave great stiffness in respect to lightness. However for the CA V8 that followed after - carbon fiber cam covers were banned - thus if they had to make the covers in cast aluminium keeping the I-beam design, the lightness would have been lost. I guess the v8 was a pair shorter too which helped in terms of making it torsionally stiff using a more conventional head design.
The later CA V8 3 piece head shown below - cam bearing ladder + cam cover not shown,
Brian,
579
Needs some smoothing but you get the idea.
16mm lift is outrageous! Duration at 1mm lift is 268 crankshaft degrees.
stevesingo
stevesingo
42
I'm surprised at the relatively short duration.
I guess that this is the advantage of the valve train's ability to accelerate the valve so quickly to such a high lift. I guess the duration measures at 5mm lift would be far in excess of anything normal.
Very nice piece on this =D>
63l8qrrfy6
63l8qrrfy6
368
gruntguru wrote: ↑
26 Jun 2018, 05:48
https://i.imgur.com/XhG0Gb0.jpg
Interestingly, if you CMM a poorly ground cam and use the measured lift profile to differentiate acceleration you end up with very similar high frequency "errors" which in reality do excite spring frequencies and fatigue them much quicker than a perfect acceleration curve would suggest.
Brian, thanks for another great post. If you're happy to supply dimensions for the entire valve train I'll sign up to mock something up in CAD and see how much we can learn from this - torque to turn, dynamic behaviour , cam stresses etc.
strad
117
Thanks Brian =D> ...I'll have convert those numbers to inch measurements to wrap my head around them.
Sir Stirling Moss
Zynerji
112
Would anyone mind explaining the quill shaft, what it does, and why it's useful in this application? It would just seem to add a variance to the position of the valve in my mind, leading to possible in-cylinder collisions with the piston.
Im super interested in understanding this concept, so any explanation from the group would be most welcome!
670
it should reduce that variance (and damage)
by decoupling (reducing the frequency response of) the camshaft to the torsional vibration (oscillation) within the crankshaft rotation
avoiding would otherwise be high amplitude responses (resonance) in the camshaft and cam drive rotations
Zynerji
112
Tommy Cookers wrote: ↑
26 Jun 2018, 23:26
by reducing the frequency response of (decoupling) the camshaft
Thank you. Is this used in any production engines?
