Burning coolant fluid
NL_Fer
NL_Fer
82
With a sharp limit on oil consumption, the tech-heads must be looking for other ways of adding some to the combustion. How about coolant? What is possible to add in the fluid and what could be gained?
Even if a combustable additive is not possible, how about preventing knock or even just cool the charge temperature. Any ideas if such is possible or why not.
Re: Burning coolant fluid
Don't know how you would bring that stuff in to the combustion chamber you can't just add another valve and pump it in there I think.
Engine oil wasn't simply injected in to the cylinder, that was/is rather complex.
lucafo
I was thinking about the white smoke from ferrari. I could see it some times during the german gp again.
The smoke stopped since the begin of the season, but now it looks to be back again.
Maybe they are cooling something else.
The smoke seens to be just below the rear lamp.
Anyone have seen it either?
470
That is oil burning on startup.
The plume near the brake light is oil from the crankcase breather.
I can't see how you could introduce coolant to the combustion process in a manner not obviously illegal.
Maritimer
Maritimer
19
Water soluble oils don't burn very nicely, especially once they're in solution. The vapors can be flammable but I doubt you would get much useful energy from them in an engine. Plus theres the matter of getting your coolant into the cylinder without there being potential for the engine to pump gases into the water jacket. Probably not a path worth going down.
roon
roon
412
Incidental leakage of non-fuel and combustion air fluids into the intake plenum is permitted. Whatever that means. "Oh, yeah, incidentally we're leaking 40hp worth of steam through the turbine! Oops!" :lol: But seriously, why not? I commend the OP's suggestion.
AJI
AJI
27
roon wrote:
27 Jul 2018, 01:43
...we're leaking 40hp worth of steam through the turbine! Oops!" :lol: But seriously, why not? I commend the OP's suggestion.
Indeed, why not!
roon
roon
412
What a strange looking Ferrari.
AJI
AJI
27
roon wrote:
27 Jul 2018, 02:20
Ironically, it's rumoured that the Stanley Steamer had 38Hp!!!
Perhaps you can re-post your original idea in the Ferrari PU thread? Get everyone thinking about a different approach.
470
Maritimer wrote:
27 Jul 2018, 01:10
I don't think you'd use coolant for combustion, as such, but to provide an anti-detonation effect.
But since it could not enter the compressor inlet legally, and any leakage would probably cause problems with lubrication, I think it is highly unlikely.
NL_Fer
NL_Fer
82
What if we use the intercooler and its fluid? A little engineered leak in the radiator, only to start spilling if the pressure is increased?
roon
roon
412
Yeah. Only about 28k microtube seals to ensure aren't leaking. 8)
strad
117
At one time they tried water injection in high performance drag type engines but that was an injection system similar to nitrous and would be very obvious. Also I assume they use some trick water wetter that wouldn't be good for the internals.
Sir Stirling Moss
Maritimer
Maritimer
19
strad wrote:
27 Jul 2018, 19:25
Water and methanol is the standard mix. They used it in F1 in the 80s when the cars ran on toluene, tons of people use it in drag racing now. Been banned in all major racing series for quite a while though.
strad
117
Thanks Maritimer;
As an old time drag racer I am aware of the mixing of alcohol and water. However there has been the use of straight water to cool things as well. But you are correct that drag racers often used a mixture. As I said though it usually required plumbing that scrutneering would spot.
Of course the guys in F1 are pretty sharp on hiding things but I doubt they are doing it. What is your opinion?
Sir Stirling Moss
