So you think the order is
Mercedes
Ferrari
Renault
RBR
Alfa
or maybe
Talk about hypocrisy.
Atleast one can assume, even with low rake, a car can be faster.
hopefully that accounts for a fair bit of the gap, remember when the disaster that was nissan's LMP1 car ran at Le Mans and were loosing seconds over a lap because the drivers couldn't touch the kerbs, in that case it didn't matter much because the whole thing was so bad but maybe with running over kerbs, williams are at least in touching distance of being a respectable slowest rather than the current embarrassing pace.
fully agree with you Phil, but still there are some that think after Melbourne Qualifying the season is over and the pecking order is written in Stone
"We had difficulties with the setup," sports director Helmut Marko admits. "If we made the car faster in two corners, it got worse in two other corners." The Red Bull engineers therefore decided to declare the second training test drive. It was more important to find a good balance, so check how much the tires break down. "We saw on Gasly that we are doing well."
Verstappen tried several voting options on the RB15. His car was refueled again and again because of the better comparability between the individual test rounds. The Dutchman never had a free round, so that the eight-tenths do not correspond to the true backlog. "But even if everything went well, we'd still be half a second behind," Marko admits. One of the top speeds and acceleration values already indicates. Honda has massively caught up with Ferrari and Mercedes.
In other words, the pre-season testing showed that the top teams had a gap to the midfield of about 0.9s. This is still accurate, given Mercedes is 0.9s to a second ahead of the midfield. The only inconsistency with expectations is that Ferrari is barely ahead of the midfield, so it's safe to assume it was simply Ferrari who were struggling with set-up and not that Mercedes are simply way ahead of everyone because they are faster.AMuS wrote:Die Frage, ob Mercedes in Barcelona nur geblufft hat oder Ferrari am Freitag in Melbourne unter Wert geschlagen wurde, ist eigentlich schnell beantwortet. Der Abstand von Mercedes zur Spitze des Mittelfeldes ist mit 0,9 Sekunden gleich geblieben. Ferrari und Red Bull dagegen hatten in Melbourne nur ein Zehntel Luft. Also müssen sie Probleme gehabt haben.
I believe they plan (or at least tested) to run asymmetricBwajSF wrote: ↑Fri Mar 15, 2019 11:27 amFerrari were reported to be using different wheelhub designs for the left and right wheel itself.GPR -A wrote: ↑Fri Mar 15, 2019 11:15 amWeather prediction for tomorrow, is going to be far more hotter than today.zibby43 wrote: ↑Fri Mar 15, 2019 8:24 amFerrari front left from FP2:
https://twitter.com/albertfabrega/statu ... 68480?s=21
https://i.screenshot.net/9p3x2ul
so may be now they know which hub not to use for the weekend...
Of course we can't tell for sure, im just asking his guess.
Well to answer it partially..... Renault ain't infront of RBBill_Kar wrote: ↑Fri Mar 15, 2019 12:19 pmOf course we can't tell for sure, im just asking his guess.
