FIA launches another engine regulatory crackdown focused on ERS
RaceFan1
RaceFan1
I'm surprised by the lack of coverage on this new FIA initiative. AMuS and insideracing are the only sources I've found.
https://insideracing.com/index.php/form ... sed-on-ers
Partymood
Partymood
-3
Re: FIA launches another engine regulatory crackdown focused on ERS
RaceFan1 wrote:
Thu Aug 20, 2020 6:00 pm
I'm not surprised...
I read articles about it on Italian sites since the beginning of the week.
Also, something I haven't yet seen on other Countries sites, there's the news that MERC and Honda asked for the ban on party mode to be delayed at least until MONZA so that they can run test on the bench.
El Scorchio
Partymood wrote:
Fri Aug 21, 2020 11:51 am
The cynic in me cannot help but think all this new engine reg stuff is entirely for Ferrari's benefit, because of the mess they've gotten themselves into.
Big Tea
97
El Scorchio wrote:
Fri Aug 21, 2020 12:25 pm
The cynic in me says Ferrari were doing it and got caught, so share the pain-
El Scorchio
Big Tea wrote:
Fri Aug 21, 2020 12:36 pm
Yes exactly- it feels like they are just assuming guilt on the part of all the other manufacturers, just because Ferrari can't seem to keep up with some of them by strictly legal means.
And if therefore Ferrari are saying to the FIA as part of their deal 'Well WE can't figure out why they are so quick and can't make ourselves as quick, so therefore there must be something dodgy' which has led to this, then that truly stinks.
I guess now we know what:
“The FIA and Scuderia Ferrari have agreed to a number of technical commitments that will improve the monitoring of all Formula 1 power units for forthcoming championship seasons as well as assist the FIA in other regulatory duties in Formula 1 and in its research activities on carbon emissions and sustainable fuels.”
really means. They're going to get everyone's designs and give them to Ferrari to analyse... :lol:
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools." oh, and "The Dutch fans are drunk. Maybe"
SiLo
103
Just to make sure I am clear on what they are looking for...
Asking for these auxiliary systems drawings makes me think that engine manufacturers might be sending current into an auxiliary component, and then diverting that somehow back into the main ERS system to get around a sensor?
Surely this would be easy to see, as there would need to be a connection back into the ERS system AFTER the sensors? Otherwise, surely all the current would still be going via the sensor?
Felipe Baby!
Easy enough to stop shunting current around the system - stick some low-rated fuses around the place. If that ECU only needs a handful of 12 Volts and 10 Amps, why are you chucking 50Amps its way? Stick a 15A fuse in front of it please. :lol:
Big Tea
97
SiLo wrote:
Fri Aug 21, 2020 2:18 pm
Is this a problem to the teams? I thought it was in and out of and the limit to storage that was the block. ?
Are they likely to need to harvest while powering the re-gen? (above the H use which is allowed is it not??)
RaceFan1
RaceFan1
I believe the talk last season was powering the MGU-K directly from the MGU-H without going through the battery and the electrical sensors. Possibly limiting the maximum RPM of the turbo by generating power directly into the MGU-K.
henry
320
RaceFan1 wrote:
Sat Aug 22, 2020 9:40 pm
The regulations allow the MGU-K to be powered directly by the MGU-H. The energy has to pass through the IVT sensor at the MGU-K.
The regulations also allow the MGU-K to be fed simultaneously by the ES and the MGU-K. SOME of the energy goes through the IVT sensor at the ES and ALL of the energy goes through the sensor at the MGU-K. Somehow the FIA decide how much comes from each source, they have to to control the 4MJ ES to K limit.
Perhaps they bypass the sensor at the K but they might also take advantage of the method that apportions energy between the two sources. Or they might do nothing at all.
Partymood
Partymood
-3
Just_a_fan wrote:
Fri Aug 21, 2020 1:56 pm
Big Tea wrote:
Fri Aug 21, 2020 1:53 pm
Just_a_fan wrote:
Fri Aug 21, 2020 1:24 pm
Dont know if you really need the smiley though
Yeah, have to make it a joke or it'll be considered an attack on the integrity of the Red Team. And we know where that will end... :wink:
[...] May I remind you of MERC secret tyre test? Or perhaps Macca's spygate? And I only mentioned what has been proven and sanctioned. [...]
Reason: Cut silliness
Big Tea
97
Partymood wrote:
Tue Aug 25, 2020 11:57 am
If you are anything but a Ferrari fan, you do have a point.
Zynerji
108
Can we just freeze the ICE and uncap the ERS system?
Let them push the ERS tech for performance gains. This is legitimately the most road relevant tech in F1.
flexcon
flexcon
Random meandering thought.
Ferrari agree to technical details of their engine being shared which leads to FIA ordering this clampdown.
Ferrari knew this and built this years engine bulkier, stronger and able to withstand a higher power mode in the race
Ferrari have bided their time on this. Taken some pain knowing the others would be chasing qualifying top end power Ferrari New Spec 2 will allow them to run this new higher map during the race for longer than the others
Ferrari close the gap to others again.
Disclaimer - Thought of this while half asleep this morning. As you do...
