Home made bench grinder / drill
Steven
Owner
Hi,
I'm trying to build myself a circular grinder (or fixed drill) for a bench, but I'm left wondering which motor to use for that. I've seen some DIY videos here and there, with some people using motors really big motors, but I think something like in a hand drill would do.
Essentially, I want a motor that I can "easily" fix on a board, with adjustable speed (0 - 200rpm would actually be enough)
Any ideas where I could find such a "simple" motor and speed control?
Big Tea
99
Re: Home made bench grinder / drill
Steven wrote:
21 Sep 2020, 21:21
Hi,
Essentially, I want a motor that I can "easily" mounted on a board, with adjustable speed (0 - 200rpm would actually be enough)
A drill. You get the chuck then too. you can replace the trigger with a Potentiometer if you use a cordless too.
For a quick job, I use a 'handle' that used to clamp on behind the chuck bolted to a 'G' clamp.
( https://uk.banggood.com/search/dc-motor ... l?from=nav )
Steven
Owner
Your link doesn't work...
Big Tea
99
Steven wrote:
22 Sep 2020, 08:25
Sorry, tried several times to correct it but having no luck .
search at banggood.com for dc-motor speed control. Any of these, the cheapest is fine.
I use the original 'trigger' on one with a cable tie around it.
( https://uk.banggood.com/Universal-Mini- ... rehouse=CN ) if you are able to clamp the drill, some do not have a suitable place.
Do you need it large? Mostly I use a dremel style tool that comes in a kit for around £20 (cheap ones not real Dremel) . There are so many good projects on youtube to do just about anything with them
nzjrs
Big Tea wrote:
22 Sep 2020, 10:35
Steven wrote:
22 Sep 2020, 08:25
I've done a few home made CNC type things and I would agree with Big Tea about the drill in principle.
I think things like dremel and routers (used for home made CNC, e.g. DWP611) have very poor low RPM torque, which would rule them out for use as a grinder I guess.
Big Tea
99
nzjrs wrote:
22 Sep 2020, 10:45
Big Tea wrote:
22 Sep 2020, 10:35
Steven wrote:
22 Sep 2020, 08:25
The 775 motor in most drills is poor for torque too but usually work through a planetary gearbox to multiply it.
A small dia. grinder in a dremel tool is usually quite good, but as you say, as it goes to larger dia. disks it stalls.
Steven
Owner
I think I'm going going to get some cheap motor and a pwm voltage regulator, and see how far that gets me.
Maybe I'll learn a thing or two from this, and then know if it's sufficient, or what I really need to look for.
dans79
267
Steven wrote:
21 Sep 2020, 21:21
Hi,
What exactly are you trying to build, I'm not really seeing it. Sounds almost like you want to make a slow speed carbide lap.
Without knowing more, the first thing that comes to mind is a small stepper motor (nema 17 or 23), and then you could just control it with a raspberry pi or arduino.
197 104 103 7
Big Tea
99
There is a very basic one here. you can modify it in many ways
flynfrog
kalinka
kalinka
a washing-machine universal motor would be OK for you. It has a great low RPM torque, and can be controlled with simple controllers. The downside is, it is quite big and heavy.
https://www.youtube.com/watch?v=2qFUQw2IHwg
kalinka
kalinka
kalinka wrote:
05 Oct 2020, 08:05
EDIT: Also, it has a tach out which helps with precise RPM control, and the RPM can be measured easily with a simple microcontroller, or a dedicated circuit.
