Induction System
Ari G
Ari G
Induction System
Can anyone share pics-Drawings ect.. on the induction system of the Formula1 Engines
Looking for Cyllinderheads,valve size,flownumbers(Velocity),Runner Size ect..
G37Sam
G37Sam
Re: Induction System
I dont think that info is available to the public
autogyro
autogyro
I dont believe it is available but I do not see why not.
First, who is going to copy it and two, it is obsolete in the scheme of things now anyway.
autogyro
autogyro
In fact if I was building a current F1 engine, I would be schemeing up ideas to make money on releasing the specs.
ESPImperium
ESPImperium
64
The regs are there as a guideline and are as tight as you can get, but the CAD drawings and blueprints arnt widely avalable.
There are some drawings about for engines used in the 90s arround on the internet somewhere, as well as drawings of old Prost Chassis somewhere as well.
THey have a video about one of the cosworth engines where you can see the drawings of the engine.
A high power motorcycle engine could be a good insight too.
Pachoba
Pachoba
Good day,
I build model f1 engine. All sizes can have a few basic dimensions. These are expressed as a multiple of something (bore). You can find the dimensions of: intake/exhaust valves, shank diameter of the valve...
It is old technology, but reliability.
for example:
use article: Theory of engine 5(pics)
f1 bore: 98mm
fuel: gasoline
roof shape combustion chamber
2x intake valves, 2x exhaust valves
INTAKE VALVE(S in pictures) = 0,35 to 0,37 x D
EXHAUST VALVE(V in pictures) = 0,28 to 0,32 x D
D is bore
count:
diameter intake valve:
0,35 x 98 = 34,3mm minimum
0,37 x 98 = 36,26mm maximum
diameter exhaust valve:
0,28 x 98 = 27,44mm minimum
0,32 x 98 = 31,36mm maximum
Language this links is Czech Language. Please use to translate.google.com
Code: Select all
Theory of engine 1:
http://skoda.panda.cz/clanek.php3?id=387
Theory of engine 2:
http://skoda.panda.cz/clanek.php3?id=388
Theory of engine 3:
http://skoda.panda.cz/clanek.php3?id=397
Theory of engine 4:
http://skoda.panda.cz/clanek.php3?id=413
Theory of engine 5:
http://skoda.panda.cz/clanek.php3?id=433
I hope help you. :wink:
