timbo wrote:MadMatt wrote:
Thank you for the link. Just a shame it is a 120° engine but I will try to contact him anyway. Hope someone can come up with dimensions of a V6 engine, doesn't matter F1 or not, it just has to be an engine used in quite high level of motorsport, so the the engine is quite compact !
That was just an example.
There are quite a few used F1 cars in various collections around. Tracking those guys might give you the info you're looking for.
Also, check this sight and contact them:
http://www.gurneyflap.com/
Yes I will try to find these guys. Its just a shame that nobody ever took measurements of these engines when they had them in the hands. Rather than always publishing the power, torque, bore, stroke and usually stuff you can find everywhere, the journalists should publish the actual size of the engine, that would be nice to imagine how compact/developed they are !
WhiteBlue wrote:Guerneyflap has a height of 627 mm for the 1988 engine. The schematic drawings in the paper should help with width.
Yes, that's already a good start, but how to know where the height has been measured ? Is it from the bottom of the engine to the top of the head ? I will have to send him an email, but I remember he's there on the forum so will drop a PM !
