2026 Aston Martin Aramco Formula One Team
zoroastar
Re: 2026 Aston Martin Aramco Formula One Team
diffuser wrote:
04 Jul 2026, 21:10
FNTC wrote:
04 Jul 2026, 19:54
SSJ4 wrote:
04 Jul 2026, 19:48
https://encrypted-tbn0.gstatic.com/imag ... t1bdeK1g&s
He has no clue. Why listen to him?
2.5 seconds at monaco quali, would have put them in the top 5 in Q1.
2.5 second imprivement on a 75 second lap is 3.33% improvement. Project the same improvement at Silverstone, which was a 99 second lap, would translate to about 3.30 seconds. Plus, it's hard to factor in how much more aggressive the drives get if tgey feel more confident in the package.
That's why we wait to see the upgrades before we speak.
yeah basically, any press member talking about this stuff is throwing random numbers at a wall to get people to read them. if the upgrade is 2 seconds at spa, it could be 3 at hungary (or vice versa), and either way, theyll finally be working on bringing updates at races to continuously make the car faster. just like all the other teams, before they commit to 27.
OnEcRiTiCaL
OnEcRiTiCaL
SSJ4 wrote:
04 Jul 2026, 19:48
This is true ,i mean he is more right than not right! Aston Martin problem is everything! The aerodynamic,the chassis, the engine, the weight, the gearbox, battery, the management system, the energy recover efficiency,plus others also not sleeping...
etusch
131
zoroastar wrote:
05 Jul 2026, 03:29
diffuser wrote:
04 Jul 2026, 21:10
Where are the 2 or 2.5 seconds? I think that's given as qualifying performance. But considering the car's good starts and if the race pace is good, consistent points might be possible. So, they could start from 16th-17th and gain a few positions at the start. Will the race pace be at a level to keep position?
FNTC
FNTC
This counts, right? :lol:
FNTC
FNTC
Another new battery for Lance, 10 place grid penalty, so starts behind Alonso.
1 more race after this one.
GoranF1
GoranF1
149
1 race to go....
krich
krich
I’m a bit more hopeful today, idk why
SilviuAgo
179
No words needed....
Otromundo
Seriously, how boring! Luckily, there's less and less left... so we can see something positive... supposedly.
Believe half of what you see and none of what you hear.
Ashwinv16
https://x.com/HondaRacingF1/status/2073 ... 19541?s=20
Honda confirms new engine for Dutch GP so nothing for Spa and Hungary in terms of engine.
Halo not as bad as we thought
SilviuAgo wrote:
05 Jul 2026, 20:14
No words needed....
Not sure what happened there. I watched Stroll's onboard through the pit stop and pit exit. He seemed to have all kinds of trouble bringing the new hard tires up to temperature. Whether that was the actual issue or if something else was going on, I don't know. I assumed it was the tires because nothing else appeared to have changed from before the stop, and up to that point he had been defending well.
Alonso was clearly the quicker of the two, but Stroll did an excellent job defending. I then switched back to Alonso's onboard. The fresh hard tires were a little tricky at first, but he got them up to temperature fairly quickly, and the car looked well-balanced in his hands. The problem wasn't the handling—it was simply lacking pace.
The biggest weakness was its top speed. Whenever Alonso was shown blue flags, he often didn't even have to lift on the straights. The faster cars would simply drive past him while he stayed flat on the throttle.
bigblue
Why (1) have you posted a ChatGPT transcript in your post, (2) are you really using ChatGPT to reword your own thoughts about the race?
bigblue wrote:
06 Jul 2026, 02:22
I was in a rush, sorry. I use it to check my gramner. Plus I'm dyslexic, it helps get it all together.
TyreSlip
TyreSlip
I wonder if Aston Martin is going to use their filming day prior to Hungary. A lot of data to gather before the summer break.
