trinidefender
317
Tommy Cookers wrote:
14 Sep 2021, 22:30
LaplacesDemon wrote:
14 Sep 2021, 21:13
For the same power higher voltage means lower current. Resistance losses increase with the square of current so increasing the voltage leads to higher ERS efficiency.
not so
consider using a lower voltage for the same power as the original
eg halving the voltage means doubling the original current
this will require a quarter of the original armature resistance
so the resistance losses in the armature will be unchanged
Wouldn't one of the benefits of higher voltage be thinner and lighter wiring around the car for the same resistance or lower resistance with the same wiring? this may lead to a smaller and lighter PU. Maybe the main advantage is packaging.
Zynerji
111
trinidefender wrote:
15 Sep 2021, 02:43
14 Sep 2021, 22:30
14 Sep 2021, 21:13
not so
I think it's heat loss from resistance, and possibly some switching issues get better higher voltages.
mzso
59
14 Sep 2021, 22:30
not so
Yes so. Decreasing losses is the only reason for using high voltages on power lines.
617
mzso wrote:
15 Sep 2021, 05:45
14 Sep 2021, 22:30
not so
not so
unless the F1 car weight limit has been waived
otherwise it doesn't matter that the cabling weighs more (to have the same losses as with a higher voltage system)
I think the argument towards higher voltage lies elsewhere (there's a lot of elsewheres)
sosic2121
15 Sep 2021, 09:40
mzso wrote:
15 Sep 2021, 05:45
14 Sep 2021, 22:30
not so
not so
I believe you are wrong.
IMO higher the voltage, higher the efficiency of the whole system. Drawback is that higher voltage requires better insulation, but still it's worth it.
We are talking about hundreds of amps.
617
sosic2121 wrote:
15 Sep 2021, 11:41
15 Sep 2021, 09:40
... I think the argument towards higher voltage lies elsewhere (there's a lot of elsewheres)
IMO higher the voltage, higher the efficiency of the whole system....
I have only said that machine conductor or cable resistance won't be the reason for Ferrari's higher voltage
and nobody has suggested anything else machine-related
the rpm and current combination of the H is at the limit of transistor capabilities (in what the FIA calls the CU)
(ie 250000 rpm 'motors' are possible but only at far lower powers than the H)
maybe for the H machine a higher voltage/lower current helps here ?
or maybe it's related to developments on the battery side ?
ryaan2904
36
sosic2121 wrote:
15 Sep 2021, 11:41
15 Sep 2021, 09:40
mzso wrote:
15 Sep 2021, 05:45
not so
A bit of a noob question here, but at what point do you decide that going higher isn't worth it, for eg. going for 1000v or even 1200v
CFD Eyes of Sauron
sosic2121
ryaan2904 wrote:
15 Sep 2021, 15:06
[/quote]
I guess you would first have to decide what percentage of power lost in cables is acceptable. Less you loose in cables, more you can send to K and H.
But I believe in F1 scenario, higher is always better.
codetower
sosic2121 wrote:
15 Sep 2021, 11:41
15 Sep 2021, 09:40
mzso wrote:
15 Sep 2021, 05:45
not so
Do we know what the change in Amperes are? I'm no electro-magician, but the way I understand it is an increase in volts doesn't mean an increase in Amps (its the opposite actually). Amps are the amount of electricity through the circuit, Volts are the measure of the force, or the “volume”. The resistance in the circuit will determine how many amps are being pushed. The wattage (the actual workload) will be Amps x Volts. The way I understand it, increasing the voltage like they are doing will allow them to reduce the current, making the system more efficient. This could allow them to run the power for longer stretches, recharging time is reduced, therefore giving them more power.
Again, I may be way off here. This is all just my theory based on the limited knowledge of electronics I have (one of my college electives I took just for fun).
mzso
59
15 Sep 2021, 09:40
not so
Well, you didn't discredit Ohm's law, which you (unintentionally?) did before.
And you didn't quite respond to the previous line of comments
15 Sep 2021, 09:40
I'm quite sure they can't use huge heavy coils with spaghetti thickness copper wires efficiently. Especially at 120k rpm.
Weight limit, or not.
15 Sep 2021, 13:52
Even if any/all of this is true, why wouldn't the resistance also be a reason?
DoctorRadio
Weren’t the advantages of higher voltage in Daimler’s article posted above?
https://media.daimler.com/marsMediaSite ... d=44056073
“ Another area where you can see similar developments in the road car world and Formula One is the introduction of high-voltage systems. Why? In an electrical system, energy loss manifests itself as heat which is not a welcome effect in a car. The losses can be reduced by reducing the current. In order to reduce the current while keeping the power the same, you need to increase the voltage. In F1, we’re now close to 1,000 volts with the ERS battery. Modern electric road cars usually operate systems of up to 400 volts; however, the voltage will increase in the future and be closer to the voltage used in Formula One today”
617
https://www.youris.com/mobility/traffic ... ctric-cars
(people might need to search for this by title)
it seems to say that higher voltages are to ....
reduce amounts of copper needed on (road) cars and ... reduce their battery charging time so to allow increased range
and we could think that future Ferrari road cars are expected to be competitive with future Mercedes road cars
it does not seem to say that onboard efficiency increases with higher voltages
https://chargedevs.com/features/a-close ... onductors/
https://chargedevs.com/features/a-close ... ev-motors/
don't seem to offer a quick answer to that question
typically physical or electronic 'commutation' might have a fixed voltage loss ie favour higher voltage/lower current
but the 125000 rpm c.100kW H machine isn't the typical
mzso
59
17 Sep 2021, 11:10
It's the same thing actually. You increase the voltage, the current can be reduced. So you either have better efficiency, or you use thinner wires and save weight, depending on what's important. Which of course applies to all conductors, including the coils in a motor.
Now how power electronics function with the different voltages isn't. I think only an expert with knowledge of the cutting edge power electronics could answer that reliably.
Zynerji
111
mzso wrote:
17 Sep 2021, 19:47
17 Sep 2021, 11:10
I would assume that the inverter and switch mechanisms have some sort of influence on this as well...
mzso
59
Zynerji wrote:
17 Sep 2021, 21:00
Well, the inverter would be the main part of the power electronics. Not sure what you mean about the vague "switch mechanisms"
