I do not think so. You would just grill your tires in the first 9 corners until turn 10 is the first one flat.AeroDynamic wrote: ↑Thu Nov 25, 2021 4:39 pm
Qualifying will be a disaster with everyone hunting a tow
Same goes for overtaking...I fear this will not be easy if there is no wind reducing a bit the dirty air issue. You simply can not follow from T1 to T10 for sure, then you have from 13 to 16 again a series where you can not follow until you reach the high speed stuff, but is this enough if you have to follow through T22 a high speed corner in the middle?
My guess is, that most overtaking will happen into T1 if one can manage to get close in the last corner.
