dialtone
dialtone
139
glenntws wrote:
10 Apr 2022, 08:54
etusch wrote:
10 Apr 2022, 08:43
is mgu-k smells when failure? I think Carbon fiber body part or some fluid burnt.
The audio sounded to me like the MGU-K failed shortly before max turned off the engine.
Gasly also had the fluid leak at the MGU-K when it failed (maybe overheating is the problem?) which then started burning.
Pretty sure it's the same problem. Was Max still on a old MGU-K and did Perez get a new one? Or did they just not want to give hints on the radio... Maybe the new K for Max will have the problem resolved, I think he was still on the first one.
EDIT: Read somewhere that Gaslys failure was Battery related... Could also apply to Max, hence the immediately stopping MGU-K.
Horner just told Sky that it could maybe still be a fuel issue. Engine was on fire though... not sure what to believe.
mzso
mzso
76
glenntws wrote:
10 Apr 2022, 08:06
MGU-K failure again, 100% sure. Ffs.
Was the Gasly thing an MGU-K failure? The last claim I head was that it was a battery failure.
But if Verstappen smelt something strange before it caught fire, it should be cooling oil from the MGU.
Spoutnik
Spoutnik
glenntws
glenntws
87
Spoutnik wrote:
10 Apr 2022, 09:46
Well, my assumption was wrong and on the one side I'm happy the Honda PU did it's job, but (OT): C'mon man, it can't be that hard to get the fuel system right. Get your stuff together RB.
apriandy
apriandy
glenntws wrote:
10 Apr 2022, 10:22
Otherwise, I believe the PU is not in a good shape since the preseason test in Barcelona, with fuel pump issues and MGUK-shaft failure. Now, Redbull and AlphaTauri have to deal with fuel and MGU-K issues in every race weekend(?). Redbull and AlphaTauri always defending the PU, I don't know why.
lio007 wrote:
09 Mar 2022, 13:10
lio007 wrote:
08 Mar 2022, 07:34
Are there any serious concerns about the fuel pump issue and MGUK-shaft failure they had in Barcelona?
https://www.auto-motor-und-sport.de/for ... lona-2022/
On the second day of testing, the problems first affected the gearbox and later the power unit. Parts like the fuel pump had shaken loose and maltreated the power unit. The shaft for the MGU-K broke.
I am afraid that Honda didn't put enough effort to overcome the new regulation. I'm afraid Honda just gave the RA621H+E10 modification, that's it, full stop. Hopefully, Honda would consider to "be back", and collaborate even further behind the scene. Because the situation right now is really heartbreaking.
Alexf1
Alexf1
What's going on with the fuel RB is using? Is it caustic? It's causing vapor lock and eats fuel lines. Very odd.
Zynerji
112
Alexf1 wrote:
11 Apr 2022, 23:45
All ethanol blends do this.
They should have material spec'd for the change, however.
Big Tea
Zynerji wrote:
11 Apr 2022, 23:55
Alexf1 wrote:
11 Apr 2022, 23:45
I wonder if they are not using the fuel for something other than squirting into the cylinder and lighting?
For instance, some rocket engines flow the fuel through the nozzle for cooling before burning it
dialtone
dialtone
139
Big Tea wrote:
11 Apr 2022, 23:56
Zynerji wrote:
11 Apr 2022, 23:55
Alexf1 wrote:
11 Apr 2022, 23:45
That would not be legal since it changes temperature of fuel, it would also increase the temperature of fuel making combustion less efficient.
Zynerji
112
dialtone wrote:
12 Apr 2022, 00:04
Big Tea wrote:
11 Apr 2022, 23:56
Zynerji wrote:
11 Apr 2022, 23:55
There was a HAAS telemetry screen pic from a few years ago that showed a hot fuel rail and an ambient fuel rail, and it seemed to be mixed at the injector to reach a specific temperature for atomization.
Big Tea
dialtone wrote:
12 Apr 2022, 00:04
Big Tea wrote:
11 Apr 2022, 23:56
Zynerji wrote:
11 Apr 2022, 23:55
Is it not 'cooling' of the fuel that is not allowed?
Amount is measured by weight, so that should not matter. Yes it would be less efficient, I think. But what would be the trade off?
dialtone
dialtone
139
Big Tea wrote:
12 Apr 2022, 00:12
dialtone wrote:
12 Apr 2022, 00:04
Big Tea wrote:
11 Apr 2022, 23:56
Yeah, cooling isn't allowed specifically, but it's not too hard to invert the behavior of a heat pump, so I would think the FIA would tell a team to steer clear of any of that.
dialtone wrote:
12 Apr 2022, 00:23
Big Tea wrote:
12 Apr 2022, 00:12
dialtone wrote:
12 Apr 2022, 00:04
6.4.2
No fuel intended for immediate use in a car may be more than ten degrees centigrade below
ambient temperature. When assessing compliance, the ambient temperature will be that
recorded by the FIA appointed weather service provider one hour before any practice session
or two hours before the race. This information will also be displayed on the timing monitors.
The temperature of fuel intended for use in a car must be measured via an FIA approved and
sealed sensor.
6.4.3 The use of any device on board the car to decrease the temperature of the fuel is forbidden
#ReleasetheADUO
mrluke
mrluke
33
12 Apr 2022, 01:23
dialtone wrote:
12 Apr 2022, 00:23
Big Tea wrote:
12 Apr 2022, 00:12
6.4.2
sealed sensor.
How does that work? If the fuel can't be above ambient plus 10 but you aren't allowed to cool it, how do you comply? I cant see that its impossible for the fuel to warm up from the engine heat, especially at hotter races. Is this to do with definition of "device" perhaps?
39
mrluke wrote:
12 Apr 2022, 02:02
12 Apr 2022, 01:23
dialtone wrote:
12 Apr 2022, 00:23
6.4.2
sealed sensor.
There is nothing about being above ambient. Only below.
