Red Bull RB18
Henk_v
Henk_v
89
Re: Red Bull RB18
I don't buy it. We are all keen to see the "anti porpoising" magic bullet and speculation about anything odd in the floor will quickly associatie wit porpoising.
Joining the ranks of the "picture aerodynamicists", my guess would be that is is just a very clever device, repurposing the rule for the edge wing to make something to controll the airflow in that region. They managed to get a sort of strake in to really force some things. Shaping surfaces only gets you limited control.
It looks like the little kick on the end really powers up the diffuser bottom vortex, sealing it.
More speculative, it looks like it seperates the main tunnel from a mini tunnel to the outside of the device, including its own kickline (and thus different pressure) which the device neatly seperates.
If you have this device it needs to be metal, because it will touch the asphalt hitting kerbs. That does not mean it was intended to do so to prevent porpoising.
gandharva
252
Re: Red Bull RB18
Juzh
161
Re: Red Bull RB18
Jeddah wing?
vorticism
vorticism
449
Re: Red Bull RB18
Some say they produce less downforce with their floor, and this help with their porpoising, but the opposite may be true. Since the floor can produce downforce more efficiently, they may be getting more of their downforce from the floor while benefiting from its relatively low drag and the knock-on effects from being able to run less wing (higher top speed).
By comparison, other teams may need to run more wing because their floors aren't producing as much DF.
wogx
wogx
60
Re: Red Bull RB18
Re: Red Bull RB18
Re: Red Bull RB18
wogx wrote:
06 May 2022, 10:02
99% sure it's about tyre temp management. Very nice detailing from RB, as expected.
gandharva
252
Re: Red Bull RB18
Nice! RBR getting on top of tyre business. Imho this has nothing to do with outwash/aero but will help to cool/heat tyres. Somehow expected as they dedicated a full session in Imola to better understand the tyres.
JordanMugen
90
Re: Red Bull RB18
Henk_v wrote:
05 May 2022, 21:14
02 May 2022, 17:24
I suspect that the skate is another red herring as it regards to "anti-porpoising'.
The Red Bull has (likely) many features to "manage" (Horner) porpoising, no? The skate could be one of them, but there shouldn't be a suggestion that there is 'magic bullet' that the RB uses to manage porpoising.
It's all the features together is it not (tunnel shape, suspension, bodywork rigidity etc), which the Red Bull team use to manage porpoising?
Owen.C93
Owen.C93
190
Re: Red Bull RB18
I think it's a bit of a reach to say it's for porposing. I think it's more acting as a skirt, or maybe controlling tyre squirt as it's exactly the same as previous gen cars had with a straight strake in front of the rear tyre.
It might be a safe guard for floor bottoming, but it's not relied on very much.
michl420
michl420
Re: Red Bull RB18
I think there is no "anti porposing device" on any car on the grid (maybe mercedes has some details by now). Because all of this specs are designed before the car hit the test track and and no one thought of porposing. Some designs are more vulnerable than others by accident. Thats how I see it.
Re: Red Bull RB18
bosyber
bosyber
45
Re: Red Bull RB18
michl420 wrote:
07 May 2022, 09:59
Yeah, I'd agree with that, as well as posts above saying it is a combination of things that mean Red Bull doesn't suffer from porpoising (as much as others). They might possibly have thought about the issue in development a bit, and I do think their very different (how Red Bull, right?!) 'boat' and tunnel shapes seem to somehow help in making sure the issue doesn't occur so strongly. But as no one really saw (could see) it in their simulations or wind tunnel, it probably is largely an amount of 'luck' in how different teams' aero and mechanical concepts work together.
Re: Red Bull RB18
A nice pic of the drum... but it's probably an inner drum under the outer drum, AKA the cake tin
+ the floor
Motorsport
bosyber
bosyber
45
Re: Red Bull RB18
Blackout wrote:
07 May 2022, 21:53
+ the floor
https://i.imgur.com/RID8Bw5.jpg
https://i.imgur.com/rBGGNX9.jpg
The shape of the (inner) drum still seems to show signs of the openings on the outside, showing where they enter/start, which is of interest.
Similar with that view of the floor for how the boat shape works.
