Mercedes W13
Mr5in1
Re: Mercedes W13
Spoutnik wrote:
09 May 2022, 00:48
Could they run both concepts over a race weekend, have one car as the original larger sidepods and the 2nd the newer one and play all set ups on both.?
Re: Mercedes W13
Mr5in1 wrote:
09 May 2022, 04:19
Spoutnik wrote:
09 May 2022, 00:48
I think that's a bid of a negative. Their windtunnel model which will be months ahead from now is most likely based on no-pod design. They cannot simultaneously develop both solutions.
#ReleasetheADUO
IGOSNELL
IGOSNELL
Re: Mercedes W13
Getting tired of Mercedes moaning. If the floor is the problem then just replace it. Does not make sense why they don't tackle
the problem head on but they just keep on analyzing data. Seems rather strange...
zibby43
zibby43
Re: Mercedes W13
IGOSNELL wrote:
09 May 2022, 07:04
lol. Pretty sure that's the exact problem they're trying to tackle. And it's a bit more difficult than you make it seem.
georgekyr
georgekyr
Re: Mercedes W13
carisi2k wrote:
09 May 2022, 00:40
The mini pods are the problem because they don't give enough support to the floor and because of this the floor is flexing and fluttering causing aero problems even in the corners. Just my humble opinion.
I believe the same thing. How this can be solved -if it can be solved- is another question. I believe we saw that for a very small window the concept can be really fast and competitive, but the boundaries of this window are so small it is very difficult to setup the car properly for a full race.
In a budget restricted era, you need all the assistance you can get from low cost solutions like CFD and wind tunnel. I believe they made the strategic decision that for the longer term, it makes sense to spend more money there (which will probably have a higher added value) that bring new pieces in a "trial and error" fashion at every race to test at the track.
The package as it is requires a very advanced suspension and I believe this is the reason Russel called for active suspension a few races back. Mercedes can probably get it to work optimally in specific conditions only with each suspension setup, something that an active suspension could fix.
Let's see the new floor (or floors) they test out in Barcelona. If they fail to become competitive, I believe they will make the decision to be third in the constructors and try to optimize their CFD and wind tunnel, improve correlation and have much better tools ready for the coming years, testing more extreme solutions whenever possible.
matteosc
matteosc
32
Re: Mercedes W13
RZS10 wrote:
08 May 2022, 10:24
matteosc wrote:
08 May 2022, 00:58
It would be interesting to see a comparison. [...]
-check link
Link: viewtopic.php?p=1044613#p1044613
Thank you for the link, it does look like they are all flexing more or less the same.
elMaestro
elMaestro
Re: Mercedes W13
Are the updates on the front, rear and the beam wing going to remain for Barcelona and come together with the new floor or were these just a low downforce config specifically for this track?
Cocles
Re: Mercedes W13
elMaestro wrote:
10 May 2022, 03:57
Just an educated guess, but probably yes for at least the front wing considering how much it plays with everything behind it. It makes sense to take the front wing to Miami, make sure it does what it's supposed to, then introduce the new floor that plays off of it at the next race.
Stu
Re: Mercedes W13
I wonder how much effect the front wing is having on floor performance. They have the most aggressive wing package on the grid (almost like the 2021 car until they started backing the rear wing off from mid-season).
Almost all of the other teams are running a much flatter front wing, although they then have side pods that pick the flow up further back; while Mercedes have the SIS cover that they are trying to similarly use.
Such an aggressive front wing must have an impact on the underfloor flow.
AA_2019
AA_2019
Re: Mercedes W13
Stu wrote:
10 May 2022, 08:27
It will be starving the underfloor of airflow
saviour stivala
saviour stivala
43
Re: Mercedes W13
With a starved under floor airflow by front wing used (reduced intake to under floor) they will be jumping/porpoising much less.
wogx
wogx
60
Re: Mercedes W13
Mercedes won't rule out ditching F1 sidepod design after Spanish GP
Mercedes has not ruled out abandoning its ‘zero-pod’ concept as it faces a crunch decision on the future of its Formula 1 car after the Spanish Grand Prix.
https://www.autosport.com/f1/news/merce ... /10302171/
pursue_one's
97
Re: Mercedes W13
According to AMuS, Mercedes is set to change the floor for Barcelona, how much is not certain yet.
They want to be cautious, since Barcelona is the important test for them.
_cerber1
296
Re: Mercedes W13
Spoutnik
Spoutnik
Re: Mercedes W13
