I mean generally speaking, a way to simulate the heating and cooling of the engine and heat soak under the engine cover.
Its not the overheating that does the damage, it is what causes other things to fail.
Sam Collins said he has to take a turbo charger too and suggests he take one from the old (previous) engine or it will be a 10 place drop
I thought you were not allowed to race a previous spec as soon as you've introduced a new spec, which according to AMUS and this same website they did on PU2 (reliability upgrade) https://scuderiafans.com/ferrari-were-a ... y-problem/ or is the reliabity upgrade not done on the turbo but on the ICE after all?codetower wrote: ↑14 Jun 2022, 13:07So it appears that the ICE and Turbo are both in-salvageable for Leclerc. They will bring a 3rd ICE with possibly the firs turbo (the only one they have in the pool) to avoid penalties.
Here’s the English translated article:
https://scuderiafans.com/baku-ferrari-i ... -salvaged/
I don't remember this rule in the past, once an engine is homologated you can bring it wherever you want.Alexf1 wrote: ↑14 Jun 2022, 16:12I thought you were not allowed to race a previous spec as soon as you've introduced a new spec, which according to AMUS and this same website they did on PU2 (reliability upgrade) https://scuderiafans.com/ferrari-were-a ... y-problem/ or is the reliabity upgrade done on a different component than the ones we're talking about here?codetower wrote: ↑14 Jun 2022, 13:07So it appears that the ICE and Turbo are both in-salvageable for Leclerc. They will bring a 3rd ICE with possibly the firs turbo (the only one they have in the pool) to avoid penalties.
You're right. It's only when you're under parc ferme that you cannot use a different/previous spec. Sorrydialtone wrote: ↑14 Jun 2022, 16:14I don't remember this rule in the past, once an engine is homologated you can bring it wherever you want.Alexf1 wrote: ↑14 Jun 2022, 16:12I thought you were not allowed to race a previous spec as soon as you've introduced a new spec, which according to AMUS and this same website they did on PU2 (reliability upgrade) https://scuderiafans.com/ferrari-were-a ... y-problem/ or is the reliabity upgrade done on a different component than the ones we're talking about here?codetower wrote: ↑14 Jun 2022, 13:07So it appears that the ICE and Turbo are both in-salvageable for Leclerc. They will bring a 3rd ICE with possibly the firs turbo (the only one they have in the pool) to avoid penalties.
Only problem is that engine (P2 PU) failed after 3 races - Miami, Spain and not even third of Baku GP.PlatinumZealot wrote: ↑14 Jun 2022, 18:16I can't see Ferrari winning the case for a reliability upgrade because there are too many factors against them.
1. Their rivals will try to stop them
2. Their engines can be turned down and still be within the acceptable range of horsepower
3. The engines seem to fail near end of life and not start of life.
4. It could be a performane gainer that is causing the problems now.
I think maybe some of the teams will want 'brownie points' in the bank with Ferrari so may chose the option that would do them the least harm short term. Merc are not going to catch either Ferrari or RBR so it will not matter to them which order they are in infront of them, and the other Ferrari engine teams are not in critical positions to anyone else.PlatinumZealot wrote: ↑14 Jun 2022, 18:16I can't see Ferrari winning the case for a reliability upgrade because there are too many factors against them.
