New centerline cooling indeed
https://www.motorsport.com/f1/news/will ... /10330724/
Quite impressive update. Will be interesting to see its influence on performance. Especially since this update means Mercedes will now be the one and only team sticking to a "micro/zeropod"-concept, what makes it obvious that this concept, like i said several times since February, is just the totally wrong way to go with the new regulary.Moctecus wrote: ↑Thu Jun 30, 2022 6:38 pmAnother perspective (via The Race):
https://i.imgur.com/K8HDYFL.png
Edit: Old vs. new sidepod inlet
https://i.imgur.com/SmvA6UA.jpg
Must have been a legal challenge or FIA clarification. Regardless there wasnt much going with that concept.SimonFW11b wrote: ↑Fri Jul 01, 2022 6:33 amIt's a shame the car never raced with its side-pod vents open. I wonder if because flawed concept or legal challenge.
Maybe their tiny sidepods required it, because they needed a bit more force to push the air through the inside of the car? Now they got more space inside the pods, which should make it easier to guide the air through them.JordanMugen wrote: ↑Thu Jun 30, 2022 11:51 pmI wonder why Williams decided on those larger radiator intakes in the first place, if they are now able to slim the intakes down significantly?
I wonder when the last time was a team fielded two cars that looked so different!Owen.C93 wrote: ↑Thu Jun 30, 2022 6:51 pmThere's a hint to how the airflow has changed when you look at the angle of the floor stay fixing between both cars.
https://pbs.twimg.com/media/FWhHSZXXwAA ... ame=medium
the inket looks like old A522Moctecus wrote: ↑Thu Jun 30, 2022 6:38 pmAnother perspective (via The Race):
