Red Bull RB18
Re: Red Bull RB18
Thunder wrote:
05 Feb 2022, 12:39
Given the TD039 stuff remains speculation at this point, please move discussions of it to team thread. Also can we please get back to topic... I get some of you are fans of RB but I do not come to this thread to see photo of max with an AT wing.
The thread is derailed the last 2 pages otherwise I wouldn't respond simply report and move on. Please, please respect that the car threads are for technical discussion
Re: Red Bull RB18
Andi76 wrote:
30 Jun 2022, 06:53
ringo wrote:
30 Jun 2022, 03:03
29 Jun 2022, 04:13
What's very interesting in that speculative piece is they show how the center of pressure moves forwards as the car lowers. This could explain the RB18's low speed understeery nature.
It will move forward if the diffuser is contributing less relative to the rest of the floor as the rear comes down.
The article does agree that the fundamebtal purpose of having rake in the car is still relevant
And yes the rake helps against the porpoising.
I agree that rake helps against porpoising. It quite logical, as one of the "tools" against porpoising is a higher ride height. With rake, you run the car with a higher ride height at the rear, so of course this will help against porpoising.
But i also think the "relevance" of rake is getting highly exaggerated here. F1 cars have a higher ride height at the rear since the 70's. In the early 2000's for example, the F1-2000 worked best with a front ride height of 10-15 front and 30-35 rear. So having some rake is a very common approach for almost 50 years. It was only the "high rake"-concept that was unusual. And no car today has a high-rake concept. So we are pretty much at rake angles today, that had been used for decades. Of course you can follow that this makes rake still relevant. But you can also say that it is not, as we are back to the common approach used for several decades with no little differences between the teams like it was before the concept of "high-rake" was used.
I guess rake is rake but the rake being run this year is nothing like what we've had in the past. We saw almost 3 degrees of rake in past years. This year, outside of preseason, you're lucky to have seen .5 of a degree.
Stu
Re: Red Bull RB18
05 Jul 2022, 00:50
Thunder wrote:
05 Feb 2022, 12:39
Thread now cleaned up. Items of technical merit have been moved to a new thread, team stuff has been moved to the team thread, and Mercedes 2021 arguments have been trashed along with ‘1+2=653’ statements around the claim of “cheating”.
PLEASE EVERYONE, post in the correct threads!!
gandharva
252
Re: Red Bull RB18
via AMUS
via motorsport.com
dxpetrov
dxpetrov
-7
Re: Red Bull RB18
Again the high downforce wing for a low downforce track.
This is important development, as similar to what Mercedes achieved towards the end of 2021 when they had superior top speed with similar rear wing configuration on the car.
This means that RB managed to remove additional drag level with the latest car updates.
This is not a good sign for the competition, as we saw a glimpse of it at the FP3 and beginning of last race! Remember that prior to that Silverstone was suppose to be a track that suits Ferrari, and then what happened. Press is overhyped with Mercedes and Ferrari and are failing to point out this, at least not as much as they should. And RB are staying silent and talking only as if they only have a ''good car''. The body language and behavior of Max after what should have been a really disappointing race, is quite telling.
ME4ME
82
Re: Red Bull RB18
They do however run with a single beam wing element.
And is Red Bulls straight line speed really still superior? I think we haven't really seen that as clearly since Miami and previously Saudi Arabia. Ferrari has made progress. Basically the two teams have converged on a good middle ground.
dxpetrov
dxpetrov
-7
Re: Red Bull RB18
yes they have, and my point is about last race, when Ferrari had super low downforce rear wing and still were not able to achieve RB top speed, who ran a barn door wing. I believe the difference was 5-6 km/h.
But even if it was less, the point is they can run a higher DF package and still have better drag coefficient. Which means the car is faster in corners and can protect tyres better in the race, and at same time not lose anything in the straights.
Cassius
Cassius
Re: Red Bull RB18
dxpetrov wrote:
07 Jul 2022, 14:51
There is convergence between Ferrari and RB indeed, but I agree with you that because they have found more floor df, cleaned up the flow, they have a better DF/drag ratio and can now shed some rear df. They do this by removing the 2nd beam wing element. They keep the larger rear wing as then it can benefit more from DRS. Because Silverstone and Austria both have 3 DRS zones I am not surprised they keep the bigger rear wing here.
Re: Red Bull RB18
Red Bull continue their iterative development of the front brake duct cooling. They have been updating this area continuously from the beginning of the season.
This new deployment has more curvature and detailing which suggests to me they're arriving at the performance level desired of their brakes. Not seeking radical redesigns but optimization
Andi76
Andi76
476
Re: Red Bull RB18
dxpetrov wrote:
07 Jul 2022, 14:39
Thats too one dimensional, i think. The Ferraris were 11 kph faster through Maggotts into Becketts. You can easily draw the conclusion now that Ferrari produces superior downforce even when they use their low-downforce wing and thats not a good sign for the competition, especially since Ferrari is only 5-6 kph slower on the straights...but thats also too one dimensional. Both caers are very close together, with a different approach. And every approach has its pros and cons. But its neither a good or a bad sign for neither of them. And these team-related track advantages are senseless anyway with two cars that are so close together.
Re: Red Bull RB18
Re: Red Bull RB18
Unfortunately don't know the source of images as found on Twitter, but the fence leading edge has seen some revision:
Interesting new shape of the inboard fence leading edge
The outboard strake doesn't look too different to me, but the pictures I have point to it because whoever added the emojis thought it was different - probably just angle
Re: Red Bull RB18
And another angle of the floor
Re: Red Bull RB18
Hmm that's pretty cool. Similar to Haas' cooling exit beneath their fin
New inboard fence extends significantly further forwards than before
Another angle of new floor leading edge geometry
Looks to me like the red line might be the original geometry and they've bonded on the blue highlighted section hence why it's stepped? Feels like in the original image & Fabrega's image there's a discontinuity in the carbon weave along the red line which I drew which suggests this theory could be true, or I'm seeing things Image
deadhead
87
Re: Red Bull RB18
Under the plank I guess
