Sergej
S2 will be McLaren territory with that slow speed / traction stuff, Norris had put an absurd S2 before the red flag.
Cs98
Cs98
euv2 wrote:
02 May 2025, 21:42
Cs98 wrote:
02 May 2025, 21:01
Idk if it's drag or the Honda engine but the RB doesn't pull hard enough anymore. They're losing out like 5 kph vs the Mercedes engined cars with DRS closed. Was an issue in SA as well.
I have only seen the deficit in races, in qualy the Honda engine does keep up but yeah, I do think the Merc is the better engine now. We'll see if the trend of the Honda PU not reaching peak performance in race holds up here, 2 long straights should give us good insights.
With DRS RB is still competitive, so it's mitigated to some extent on quali runs. They still lose time before DRS can be opened, that's clear to see on the S2 straight in the telemetry.
Sergej wrote:
02 May 2025, 22:01
We don't know the fuel load. Track was cooling. His run was later than the others. There are many factors in it.
Beware of T-Rex
chrisc90
Only other week McLaren was a second ahead in free practice and look how that turned out.
Tough to say, at the minute
euv2
euv2
Cs98 wrote:
02 May 2025, 22:02
euv2 wrote:
02 May 2025, 21:42
Cs98 wrote:
02 May 2025, 21:01
Oddly RB21 has the lowest DRS delta here whereas it has usually been on the other end of the spectrum.
euv2 wrote:
02 May 2025, 22:14
https://preview.redd.it/miami-gp-fp1-te ... bf56a963b0
This chart is not reliable. Red Bull does not have a higher non-DRS speed than Mclaren with that rear wing. The editor often uses bad data points or data points that lack context of engine modes, slips streams, and so on.
Beware of T-Rex
euv2
euv2
02 May 2025, 22:15
euv2 wrote:
02 May 2025, 22:14
Yeah, something didn't seem right, too far off the norm for RB.
Emag
Emag
137
I wouldnt be surprised if Max puts it on sprint pole.
Developer of F1InsightsHub
CjC
CjC
Emag wrote:
02 May 2025, 22:17
He’s favourite for me
Just a fan's point of view*
Monaghan interview continued
“We understand what’s happened but actually affecting a cure is not that straightforward. It may never disappear from the car.
“Can we reduce the magnitude, improve the lap time? Yes. There’s a lot of clever people in Milton Keynes who are working hard to improve step and it will come.”
Monaghan added that the upgrades, if optimised, should add speed through all corner variations for Red Bull.
“It will get us at the majority of them,” he said.
“Anytime you have a change of speed from the point you hit the brake to turn into the apex, everybody’s going to get it.
“Then it’s just the magnitude we argue over. It will come as incremental improvements and we’ll chip away. We’ll get quicker, don’t worry.”
Upgrade not for any specific corner type.
https://www.motorsportweek.com/2025/05/ ... -miami-gp/
Beware of T-Rex
CjC
CjC
02 May 2025, 22:11
Sergej wrote:
02 May 2025, 22:01
Track temp was 38 at the beginning and 49 just before the red flag
Sergej
02 May 2025, 22:24
"don't worry trust me bro" :mrgreen: they should worry if they want to keep Max in the team
f1isgood
f1isgood
02 May 2025, 22:24
I think he also said recently something like adding 2 tenths of lap time is basically like adding one to two hundredths every corner over a roughly 15 to 20 corner track. I guess this upgrade can give them that.
f1isgood
f1isgood
Sergej wrote:
02 May 2025, 22:28
02 May 2025, 22:24
:D :D
f1isgood
f1isgood
If TSU is in SQ3, expect him to give tow for VER.
